03-11-2010, 16:47 | #1 (permalink) |
Freak Poster Join Date: Mar 2008 Location: Mombasa Age: 48
Member: 722683 Status: Offline Thanks Meter: 33 | unlock ke850 dead === log: [3/10/2010 11:36:23 AM] ==== COM3 [VCP0] selected module v1.73 Device: LG-KE850 Checking data, wait... Action: "sp-unlock" direct unlock Boot ... Press and HOLD Power button now ! s-gold2: C0 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0089:887E Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE850_eeprom-static_20100310-113644.B1E.bin reading eeprom-static2... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE850_eeprom-static2_20100310-113644.B1E.bin loading data... data loaded imei: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ reading eeprom-security_ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE850_eeprom-security_ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ_20100310-113646.B1E.bin reading eeprom-complete_ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE850_eeprom-complete_ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ_20100310-113647.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-complete Writing: eeprom-complete Verifying... Verify result: 0163 Done probably you need to restore original imei after unlock process Write Done Finished, time used: 24 sec |
03-11-2010, 19:08 | #2 (permalink) | |
Freak Poster Join Date: Dec 2006
Member: 420244 Status: Offline Thanks Meter: 41 | Quote:
03-11-2010, 21:52 | #3 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hi, Try to restore original eerom file (first eeprom file, find original file by date) It's name is like C:\Program Files\InfinityBox\Pana01\LG-KE850_eeprom-complete_xxxx.B1E.bin |
03-15-2010, 08:40 | #7 (permalink) |
Member: 722683 Status: Offline Thanks Meter: 33 | have done this but stil write ***** on lcd only COM3 [VCP0] selected module v1.76 Device: LG-KE850 Checking data, wait... Action: write flash Boot ... Press and HOLD Power button now ! s-gold2: C0 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0089:887E Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE850_eeprom-static_20100315-094321.B1E.bin reading eeprom-static2... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE850_eeprom-static2_20100315-094321.B1E.bin loading data... data loaded imei: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ reading eeprom-security_ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE850_eeprom-security_ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ_20100315-094323.B1E.bin reading eeprom-complete_ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE850_eeprom-complete_ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ_20100315-094324.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Writing: Firmware Verifying... Done Writing: FFS-2/File system Verifying... Done Write Done Finished, time used: 37 min 59 sec Remove/Install battery now ! is there any other thing i should do?customer realy on ma neck |
LG KE850 dead | petiwiw | Infinity-Box | 7 | 04-11-2009 08:26 |
unlock ke850 error | hassan1975 | FuriousGold | 2 | 11-19-2007 01:49 |
Error when unlocking KE850 | James_S | FuriousGold | 0 | 10-31-2007 14:19 |
Success when unlocking ke850 witf V-power!!! | DCred | VygisToolbox | 5 | 10-24-2007 11:37 |
help unlock KE850 ***** | techlab102 | FuriousGold | 1 | 10-05-2007 06:42 |
