Old 04-27-2009, 15:41   #1 (permalink)
-==unloOok==-'s Avatar
Member: 324373
Sonork: 1573932
Thanks Meter: 38
Hyundai-W100
i cant detect with pin finder to find correct pinout
any soultion to detect with pinfinder
it is power on the cable ( L12C) but not found
i use externel power 3.6 but not detected
Old 04-27-2009, 22:02   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
lets start from checking what CPU it is based.
you either can do this by disassembling phone or by typing *#0044# and pressing green (send) button.
if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software
if yes- you must check if phone can be powered On from pinfinder power.
if yes- increase "finder activations tries" to 20 and repeat search.
Do not use any exernal power 3,6 volts.
phone must be powered only from box power
Old 04-28-2009, 16:29   #3 (permalink)
Member: 324373
Sonork: 1573932
Thanks Meter: 38
the phone powered by pinfinder , ok
supported by infinty software , ok
increase "finder activations tries" to 20 , ok
but not found pinout for this cable
i think pin finder not support this phone to found the correct rx ,tx
Old 04-28-2009, 20:54   #4 (permalink)
Member: 148515
hello!
In this case you must disassemble phone and search for Test points on PCB
Old 11-26-2009, 17:33   #5 (permalink)
Member: 4627
Sonork: 57528:debeliamark
Thanks Meter: 1,034
For all that have problem with this phone:
Hyundai W100 tested pinouts. LCD and key are up, pins counted left to right.
14 pin in line connector:
3 = Phone Rx = Box Tx = pin 2 on RJ45 plug
4 = Phone Tx = Box Rx = pin 3 on RJ45 plug
9 or 14 = Phone GND = Box 7 or 8 on RJ45 plug
WBR, DebeliaMark, BG
The Following User Says Thank You to debeliamark For This Useful Post:
Old 11-26-2009, 17:34   #6 (permalink)
Member: 4627
Thanks Meter: 1,034
P.S. No one adapter from PinFinder is compatible for this phone, but Infinity MM Module work just fine on flashing, eeprom ( FFS ) flashing and IMEI repair ...
Old 11-27-2009, 16:52   #7 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Is it really 1x14 pin connector but not 2x7 connector ?
We have got an information before that thiss phone has 2x7 connector.
Please, confirm what is this phone actual connector type.
Thank you !
Old 11-28-2009, 16:28   #8 (permalink)
Member: 4627
Thanks Meter: 1,034
yes - i have 2 pcs at me ... Well flashed and FFS repaired via your product ( Tnx for supplying last years the best multiplatform tool and for the best support to customers ... - if me own must answer thousands times for same questions like you may be will going crazy ... ) ...
Old 11-28-2009, 16:39   #9 (permalink)
Member: 4627
Thanks Meter: 1,034
Hyundai W100
Just for real view from phones ( ******* ) ...
Old 11-28-2009, 16:50   #10 (permalink)
Member: 4627
Thanks Meter: 1,034
May be more clear view in next attachment http://rapidshare.com/files/313442006/IMG_8401.JPG
The Following 2 Users Say Thank You to debeliamark For This Useful Post:
Special Hyundai Elantra Navigation DVD System Player With HD Monitor - For Hyundai E IPMART ipmart WebShop 0 12-28-2009 07:30
Special Hyundai Terracan Navigation DVD Player System With HD Monitor - For Hyundai IPMART ipmart WebShop 0 12-28-2009 07:30
Special Hyundai Elantra Navigation DVD System With HD Monitor - For Hyundai Elantra( IPMART ipmart WebShop 0 09-26-2009 09:30
Special Hyundai Sonata Navigation DVD System With HD Monitor - For Hyundai Sonata(2G IPMART ipmart WebShop 0 09-26-2009 09:30
Special Hyundai Tucson Navigation DVD System With HD Monitor - For Hyundai Tucson(2G IPMART ipmart WebShop 0 09-26-2009 09:30
Page generated in 0.21965 seconds with 11 queries
