11-06-2007, 09:17 | #1 (permalink) |
Major Poster Join Date: Nov 2003
Member: 43411 Status: Offline Thanks Meter: 1 | I can not flashed W375 - error: write at 04054000: I use v1.42 COM4 selected "smart write" active Action: flash Write: Firmware Write: Language Pack Write: Flex Skip: Eeprom Device: W375 Checking data, wait... Connect... Press and HOLD Power button... Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 460800 Set Baud Done Check Flash-1... SW version: 0.0.80 HW version: MOTOROLA_H80S LP ver: 0062_003 Flex ver: FLEX_CF_002 cpu id: 08B6 imei eeprom: 35300301195528 required SW version: 0.0.62 sp-locked: 21403. You want to write Flex in sp-locked[21403.] phone, Make this only when you understand what you want to do ! Are you sure you want to continue ? user confirmed Flex write operation for sp-locked phone Check Flash-1 Done Check Flash-2... reading ... file saved: backup_eeprom_calibration_35300301195528_20071106-111306.34E.bin Check Flash-2 Done Write... Writing: Firmware error: write at 04054000: FF error: write at 04054000: 00 error: write at 04054000: 00 error: write at 04054000: F8 error: write at 04054000: 00 error: write at 04054000: 00 unexpected answer: C03800C03800C03800C03800C03800C03800C03800C03800C0 3800C03800C03800C03800C03800C03800C03800C03800C038 00C03800C03800C03800C03800C03800C03800C03800C03800 C03800C03800C03800 error: write at 04054000: C0 unexpected answer: C03800C03800C03800C03800C03800C03800C03800C03800C0 3800C03800C03800C03800C03800C03800C03800C03800C038 00C03800C03800C03800C038 error: write at 04054000: 00 unexpected answer: C03800C03800C03800C03800C03800C03800C03800C03800C0 3800C03800C03800C03800C03800C03800C03800C03800C038 00C03800C03800C03800C03800C03800C03800C03800C03800 C03800C03800C03800C03800C03800C03800C03800 error: write at 04054000: C0 error: write at 04054000: error: write at 04054000: Write Done Failed ! Finished, time used: 52 sec Remove/Install battery now ! what restore? |
11-06-2007, 14:08 | #3 (permalink) |
Member: 43411 Status: Offline Thanks Meter: 1 | I try - not help me error: write at 04054000: FF error: write at 04054000: 00 error: write at 04054000: 00 error: write at 04054000: F8 error: write at 04054000: 00 error: write at 04054000: 00 i try on 2 computers |
11-06-2007, 14:29 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If you have tried several times and you see the same error at the same address this means that phone hardware damaged (flash chip damaged or bad soldered). |
11-06-2007, 14:55 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | You have posted here 2 logs from different PC (as per your explanation): http:///vbb/showpo...43&postcount=1 http:///vbb/showpo...08&postcount=3 and I see the same error address. Are you really tried to follow my advice and tried to use 115200 baud ? Are you really tried it on 2 PC or you just copy/paste log text and did not tried anything on other PC ? Please, give me detailed an answers to all my qestions. |
11-06-2007, 15:04 | #7 (permalink) |
Member: 43411 Status: Offline Thanks Meter: 1 | other files Checking data, wait... Connect... Press and HOLD Power button... Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 460800 Set Baud Done Check Flash-1... SW version: 0.0.72 HW version: MOTOROLA_H80S LP ver: 0062_003 Flex ver: FLEX_CF_002 cpu id: 08B6 imei eeprom: 35300301195528 required SW version: 0.0.62 sp-locked: 21403. Check Flash-1 Done Check Flash-2... reading ... file saved: backup_eeprom_calibration_35300301195528_20071106-101151.34E.bin Check Flash-2 Done Write... Writing: Firmware error: write at 040B4000: FF error: write at 040B4000: 20 error: write at 040B4000: FE error: write at 040B4000: C0 unexpected answer: 00C03800C03800C03800C03800C03800C03800C03800C03800 C03800C03800C03800C03800 error: write at 040B4000: C0 unexpected answer: 00C03800C03800C03800C03800C03800C03800C03800C03800 C03800C03800C03800C03800C03800C03800C03800C0 error: write at 040B4000: 38 unexpected answer: 00C03800C03800C03800C03800C03800C03800C03800C03800 C03800C0 error: write at 040B4000: 38 unexpected answer: C03800C03800C03800C03800C03800C03800C03800C03800C0 3800C03800C03800C03800C038 error: write at 040B4000: 00 unexpected answer: C03800C03800C03800C03800C03800C03800C03800C03800C0 3800C03800C03800C038 error: write at 040B4000: 00 unexpected answer: 3800C03800C03800C03800C03800C03800C03800C03800C038 00C03800C03800C03800C03800C03800C03800C03800C03800 C03800C03800C03800 error: write at 040B4000: C0 unexpected answer: C03800C03800C03800C03800C03800C03800C03800C03800C0 3800C03800C03800C0 error: write at 040B4000: 38 unexpected answer: 3800C03800C03800C03800C03800C03800C0 error: write at 040B4000: 38 unexpected answer: 3800C03800C03800C03800C03800C03800C03800C03800C038 00C03800C03800C03800C03800C03800C03800C03800C03800 C03800C03800C03800C03800C03800C03800C03800C03800C0 3800C03800C03800C03800C03800C03800C03800C03800C038 00C03800C03800C03800C038 error: write at 040B4000: 00 unexpected answer: 3800C03800C03800C03800C03800C03800C03800C03800C038 00C03800C03800 error: write at 040B4000: C0 unexpected answer: 3800C03800C03800C03800C03800C03800C03800C03800C038 00C03800C03800C03800C03800 error: write at 040B4000: C0 unexpected answer: C03800C03800C03800C03800C03800C03800C03800C03800C0 3800C03800C03800C03800C03800C03800C03800C03800C038 00C03800C03800C03800C038 error: write at 040B4000: 00 unexpected answer: 3800C03800C03800C03800C03800C03800C03800C03800C038 00C03800C03800C03800C03800C03800C03800C0 error: write at 040B4000: 38 unexpected answer: 00C03800C03800C03800C03800C03800C03800C03800C03800 C03800C03800C03800C03800C03800C03800C03800C03800C0 3800C03800C03800C03800C03800C03800C03800C03800C038 00C03800 error: write at 040B4000: C0 unexpected answer: C03800C03800C03800C03800C03800C03800C03800C03800C0 3800C03800C03800C03800C03800C03800C03800C03800C038 00C03800C03800C03800 error: write at 040B4000: C0 unexpected answer: 00C03800C03800C03800C03800C03800C03800C03800C03800 C03800C03800C03800C03800C038 error: write at 040B4000: 00 unexpected answer: C03800C03800C03800C03800C03800C03800C03800C03800C0 3800C03800C038 error: write at 040B4000: 00 unexpected answer: C03800C03800C03800C03800C03800C03800C03800C03800C0 3800C038 error: write at 040B4000: 00 unexpected answer: 3800C03800C03800C03800C03800C03800C03800C03800C038 00C03800C03800C03800 error: write at 040B4000: C0 unexpected answer: 00C03800C03800C03800C03800C03800C03800C03800C03800 C03800C03800C03800C03800C03800C03800C03800C03800C0 3800C03800C03800C03800C03800C03800C03800C03800C038 00 error: write at 040B4000: C0 unexpected answer: C03800C03800C03800C03800C03800C03800C03800C03800C0 3800C03800C03800C03800C03800C03800C038 error: write at 040B4000: 00 unexpected answer: 3800C03800C03800C03800C03800C03800C03800 error: write at 040B4000: C0 unexpected answer: C03800C03800C03800C03800C03800C03800C03800C03800C0 3800C03800C03800C038 error: write at 040B4000: 00 unexpected answer: C03800C03800C03800C03800C03800C03800C03800C03800C0 3800C03800C03800C03800C03800C03800C03800C03800C038 00C03800C03800C0 error: write at 040B4000: 38 unexpected answer: 00C03800C03800C03800C03800C03800C03800C03800C03800 C03800C03800C03800C03800C03800C03800C03800C03800C0 3800C03800C03800C03800C03800C03800C03800C03800C0 error: write at 040B4000: 38 unexpected answer: C03800C03800C03800C03800C03800C03800C03800C03800C0 3800C03800C03800C0 error: write at 040B4000: 38 unexpected answer: 3800C03800C03800C03800C03800C03800C03800C03800C038 00C03800C03800C03800 error: write at 040B4000: C0 unexpected answer: 3800C03800C03800C03800C03800C03800C03800C03800C038 00C03800C03800C03800C03800C03800C03800C03800C03800 C03800C03800C03800C03800 error: write at 040B4000: C0 unexpected answer: C03800C03800C03800C03800C03800C03800C03800C03800C0 3800C03800C03800C03800C03800C03800C03800C03800C038 00C03800C03800C03800C03800C03800C03800C03800C03800 C03800C03800C03800C03800C03800C03800C03800C03800C0 3800C03800C03800C03800C03800C03800C03800C03800C038 00C03800C03800C03800C03800C03800C03800C03800C03800 C03800C03800C03800C03800C03800C03800C03800C03800C0 38 error: write at 040B4000: 00 unexpected answer: 00C03800C03800C03800C03800C03800C03800C03800C03800 C03800C03800C03800C03800C03800C038 error: write at 040B4000: 00 error: write at 040B4000: 38 error: write at 040B4000: C0 unexpected answer: 00C03800C03800C03800C03800C03800C03800C03800C03800 C03800C03800C03800 retry[01] at: 040A0000 error: Error during write: 04000000 Write Done Failed ! Finished, time used: 53 sec Remove/Install battery now ! |
11-06-2007, 15:06 | #8 (permalink) |
Member: 43411 Status: Offline Thanks Meter: 1 | "smart write" active Action: flash Write: Firmware Write: Language Pack Skip: Flex Skip: Eeprom Device: W375 Checking data, wait... Connect... Press and HOLD Power button... Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 0.0.72 HW version: MOTOROLA_H80S LP ver: 0062_003 Flex ver: FLEX_CF_002 cpu id: 08B6 imei eeprom: 35300301195528 required SW version: 0.0.62 sp-locked: 21403. Check Flash-1 Done Check Flash-2... reading ... file saved: backup_eeprom_calibration_35300301195528_20071106-101519.34E.bin Check Flash-2 Done Write... Writing: Firmware error: write at 040B4000: FF error: write at 040B4000: 20 error: write at 040B4000: 48 error: write at 040B4000: 00 error: write at 040B4000: error: write at 040B4000: error: write at 040B4000: 9F error: write at 040B4000: 00 error: write at 040B4000: 2F error: write at 040B4000: error: write at 040B4000: error: write at 040B4000: Write Done Failed ! Finished, time used: 118 sec Remove/Install battery now ! ==== log opened: [06.11.2007 10:33:20] ==== Application: C:\Program Files\InfinityBox\Moto01\Moto01.exe Loading data, wait... [Infinity Box] v1.42 S/N: 07A3:010C Current model: C113(a),C114,C115,C116,C117,C118 Ready Current model: W375 Loading file v.02... w375_0.0.80_Main_H80S_K2_1175254689.34M.bin loaded Loading file v.02... w375_0.0.80_LP_A06_Cn.34P.bin loaded Loading file v.02... W375_Flex_A4_002_retail.34F.bin loaded COM4 selected "smart write" active Action: flash Write: Firmware Write: Language Pack Write: Flex Skip: Eeprom Device: W375 Checking data, wait... Connect... Press and HOLD Power button... Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 0.0.72 HW version: MOTOROLA_H80S LP ver: 0062_003 Flex ver: FLEX_CF_002 cpu id: 08B6 imei eeprom: 35300301195528 required SW version: 0.0.62 sp-locked: 21403. You want to write Flex in sp-locked[21403.] phone, Make this only when you understand what you want to do ! Are you sure you want to continue ? user confirmed Flex write operation for sp-locked phone Check Flash-1 Done Check Flash-2... reading ... file saved: backup_eeprom_calibration_35300301195528_20071106-104502.34E.bin Check Flash-2 Done Write... Writing: Firmware error: write at 04054000: FF error: write at 04054000: 48 error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: Write Done Failed ! Finished, time used: 156 sec Remove/Install battery now ! COM4 selected Action: unlock Device: W375 Checking data, wait... Connect... Press and HOLD Power button... Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 0.0.80 HW version: MOTOROLA_H80S LP ver: 0062_003 Flex ver: FLEX_CF_002 cpu id: 08B6 imei eeprom: 35300301195528 required SW version: 0.0.62 sp-locked: 21403. Check Flash-1 Done Check Flash-2... reading ... file saved: backup_eeprom_calibration_35300301195528_20071106-104819.34E.bin unlock step-1 Ok unlock step-2 Ok unlock step-3 Ok unlock step-4 Ok unlock step-5 Ok finished Ok Finished, time used: 31 sec Remove/Install battery now ! COM4 selected "smart write" active Action: flash Write: Firmware Write: Language Pack Write: Flex Skip: Eeprom Device: W375 Checking data, wait... Connect... Press and HOLD Power button... Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 0.0.80 HW version: MOTOROLA_H80S LP ver: 0062_003 Flex ver: FLEX_CF_002 cpu id: 08B6 imei eeprom: 35300301195528 required SW version: 0.0.62 sp-locked: 21403. You want to write Flex in sp-locked[21403.] phone, Make this only when you understand what you want to do ! Are you sure you want to continue ? user confirmed Flex write operation for sp-locked phone Check Flash-1 Done Check Flash-2... reading ... file saved: backup_eeprom_calibration_35300301195528_20071106-104908.34E.bin Check Flash-2 Done Write... Writing: Firmware error: write at 04054000: FF error: write at 04054000: 48 error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: error: write at 04054000: Write Done Failed ! Finished, time used: 383 sec Remove/Install battery now ! |
Can Not Flash Samsung Z107 Error: Extra License Contact Reseller | powerplay83 | Z3X-Team Products | 3 | 03-01-2010 20:00 |
D900 hang at startup.can not flash with ust. | T.Hussain | UST Pro II | 1 | 06-19-2007 16:08 |
Canīt flash SL75. Always stops at 33% | chrisonic | DreamBox | 23 | 01-07-2007 05:06 |
