12-29-2018, 18:42 | #1 (permalink) |
Freak Poster Join Date: Jan 2018
Member: 2798902 Status: Offline Thanks Meter: 11 | I can not register in GRT Dongle Web & LG program does not start in Win 10 Indicate if I should place the Serial here ? The Software "Grt Dongle Lg Tool V.1.0.0.0" does not want to start on my Windows 10 64bit, the rest of the programs work normally, "Grt Dongle Hardware Tool 1.0.0.2" and "Dongle Qualcomm Tool 1.0.0.3". Any solution? Please respond,... Last edited by GabrielCh; 12-29-2018 at 18:51. |
The Following User Says Thank You to GabrielCh For This Useful Post: |
12-29-2018, 19:13 | #2 (permalink) |
Member: 2798902 Status: Offline Thanks Meter: 11 | Dear, my Serial GRT Dongle. === Updater [grt] v1.2 [29/12/2018 2:07:48 p. m.] === Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 000138F81F444082 Serial No (S/N): 040036B7 Firmware version: 0002 |
12-29-2018, 22:00 | #3 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hi, if you can see grt serial number this means activation completed well. you can ask grt support here - GRT Dongle - GSM-Forum |
12-29-2018, 22:30 | #4 (permalink) |
Member: 2798902 Status: Offline Thanks Meter: 11 | [Quote = YellowBoss; 13484353] Hola, si se puede ver el número de serie TRB esto significa la activación completado también. usted puede pedir ayuda TRB aquí [/ quote] Thanks for answering, if you can move this thread to the link that indicated it would be happy. If indeed I can see the serial number and the programs work well, LESS the "Grt Dongle Lg Tool V.1.0.0.0" that does not start. The problem is that when you finish the Registry on your Web page, you DO NOT complete the record indicating that the "Serial Invalid" and I can not Log. Capture: h t t p s : // prntscr . com/m14p11 |
01-13-2019, 02:38 | #5 (permalink) |
Member: 2798902 Status: Offline Thanks Meter: 11 | The second problem was solved !! If you do not start "GRT Dongle LG Tool V.1.0.0.0" in Windows 10 64-bit. must be excluded the executable "GRT Dongle LG Tool V.1.0.0.0, exe" of the Windows 10 Data Execution Prevention. Fix the Link (the join separations) so you can see the image Capture: h t t p s : // prnt . sc/m1dcdy I hope that this comment will help any yours. Thanks all... |
