Old 09-07-2017, 10:13   #1 (permalink)
Member: 2747105
Thanks Meter: 21
I cant boot Oppo A37F with Cm2QLM Team Help
both volume button EDL mode done but cant boot may be my mistake plz help .software not detect phone.
Old 09-07-2017, 10:27   #2 (permalink)
princesaddam's Avatar
Member: 1010626
Sonork: using fb
Thanks Meter: 735
Hello,
Did u install Correct drivers,, Download Drivers from Support and see here how to install Drivers http://forum.gsmhosting.com/vbb/f296...video-2160627/
The Following User Says Thank You to princesaddam For This Useful Post:
Old 09-07-2017, 10:59   #3 (permalink)
Member: 2747105
Thanks Meter: 21
Drivers are all OK.....
Qualcomm HS-USB QDLoader 9008 (COM11)
this show in device manager of Pc
But Phone not Boot
Old 09-07-2017, 11:06   #4 (permalink)
Member: 1126941
Sonork: 100.1672154
Thanks Meter: 2,488
But Phone not Boot
cm2 not work with qlm9008 driver
u have to install emergancy usb drivers
process here
The Following User Says Thank You to mobi_soft For This Useful Post:
Old 09-07-2017, 11:31   #5 (permalink)
Member: 2747105
Thanks Meter: 21
Thanks A Lot Device is Connected..................
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device not found!
Check cable, connection and drivers!
Reconnect Power/Cable!
Operation : Reset Settings [ v1.15 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 20BD66B6
ID_BLOCK_I : 007050E1
ID_BLOCK_L : 3335AF57066C999473282835F249C901
ID_BLOCK_L : 94EF51F8FD64D65F72BD16CFC528C605
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ]
ExtInfo : 0x00004000/00004000/00001000/00001000/00000200
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:16
Old 09-07-2017, 22:37   #6 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,777
Can any of you test QLM Memory Tool, with attached loaders ?
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
The Following User Says Thank You to Brka For This Useful Post:
Page generated in 0.17591 seconds with 9 queries
