01-08-2010, 15:47 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: GREAT INDIA
Member: 559113 Status: Offline Sonork: 100.1596477 Thanks Meter: 760 | I cant complete touch screen cellebration module v3.04 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... GEMINI_PCB01_GPRS_MT6225_S00.L_2217C_V5_3_2_T3__fu llflash_20091230-184223.B0M.bin loaded ffs/eeprom record offset detected ffs/eeprom record size detected ffs/eeprom record offset detected ffs/eeprom record size detected Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:2E03:0007 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... warning: can't read software version, probably unknown firmware 67 byte(s) read connection lost error: operation failed ! Finished, time used: 9 sec Remove/Install battery now ! |
01-08-2010, 22:15 | #3 (permalink) | |
Banned Join Date: Sep 2008 Location: Dc-serviceteam Age: 38
Member: 857234 Status: Offline Sonork: Dc Thanks Meter: 197 | Read in all it important Quote:
read log when u work it very important .Be careful By http://djibrilcoulibaly.********.com | |
01-10-2010, 23:37 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! not modified main infinity box gives too less power to pinfinder. this is a reason of weak test mode operations with pinfinder. if you use pinfinder you defenetly must modify main infinity box. there must be diode removed and shortcutted |
3g touch screen convert to 3gs touch screen | mccm | iPhone 4 / iPhone 4S | 4 | 02-04-2011 14:09 |
eten glofiish x800 cant snync touch screen | dem3ntor | Hardware Repair by brands | 1 | 01-03-2011 13:59 |
Curious: Touch screen is not working and is not touch screen problem | trentini | iPhone 2 / iPhone 3G / iPhone 3GS | 2 | 09-04-2009 16:23 |
S4 Cant Calibrate Touch Screen ? | Chennairam | Infinity-Box | 7 | 03-09-2009 11:21 |
