12-10-2008, 00:14 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: FomTekLAB Mexico-United States
Member: 645603 Status: Offline Thanks Meter: 89 | i cant flash and unlock any Pantech 3210 |
12-10-2008, 14:25 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, You must use different cables for unlock mode and for flash mode. Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
12-10-2008, 21:46 | #3 (permalink) |
Member: 645603 Status: Offline Thanks Meter: 89 | yes sir i have the rigth pinout,because its the same with the pantech 1410 and i flash this 1410 and unlock without any problem,the problem its with pantech 3210,check that please the firmware of support doesnt work,regard |
12-10-2008, 22:06 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, As I can see you did not follow my advice. Please, do it at least next time. Pantech cable for infinity-Box has two modes, software inform you what mode you need to use for each operation: Cable name: Pantech-C300 === DATA MODE === keyboard top 1.........24 phone pin-3 connect to phone pin-4 10: Phone Rx (RJ-45 pin-2) 11: Phone Tx (RJ-45 pin-3) 24: Gnd === GPRS MODE === keyboard top 1.........24 12: Phone Tx (RJ-45 pin-3) 15: Phone Rx (RJ-45 pin-2) 24: Gnd |
12-11-2008, 17:52 | #7 (permalink) |
Member: 645603 Status: Offline Thanks Meter: 89 | because when i try to flash the phone make a godd conection but when its triyin to write the file always said a message "error write xxxxxxxx to xxxxxxxx" retry or cancel,(the xxx are number that i dont remember now) so what can i do,becuase its the same cable to flash the pantech 1410 and with that phone i dont have any problem,i hope you can help me,regard |
12-11-2008, 19:06 | #9 (permalink) |
Member: 645603 Status: Offline Thanks Meter: 89 | I dont have any more this phones ,my customer doesnt want wait more time,but im gonna recieve more phones,upload more flash,maybe tomorrow im gonna have more,regard |
12-18-2008, 21:35 | #10 (permalink) |
Member: 645603 Status: Offline Thanks Meter: 89 | COM4 [VCP1] selected Device: Pantech PG-3210 Checking data, wait... Action: flash write Write: Firmware Skip: File system Skip: Language pack Skip: Eeprom "smart write" enabled Boot... Phone must be POWERED-OFF ! Cable must be in "GPRS" mode ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 89881200010001:89881200000000 flash: Intel 128MBit-T Strata T 16Mb id: 0000527A Boot Done Set baud... 921600 Set baud Done Check flash... Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware flash: 89881200010001:89881200000000 error: no any expected answer error: flash write error: 01000000:00020000 Write Fail Finished, time used: 34 sec Remove/Install battery now ! here the log,upload more 3210 firmware please its urgent,regard |
12-23-2008, 00:24 | #13 (permalink) |
No Life Poster Join Date: Oct 2004 Age: 47
Member: 86579 Status: Offline Thanks Meter: 70 | cant flash pantech 3210 hello infinity support i am trying to flash pantech 3210 and i am having the same problem please fix this. here is log COM3 [VCP1] selected Device: Pantech PG-3210 Checking data, wait... Action: flash write Write: Firmware Skip: File system Skip: Language pack Skip: Eeprom "smart write" enabled Boot... Phone must be POWERED-OFF ! Cable must be in "GPRS" mode ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 89881200010001:89881200000000 flash: Intel 128MBit-T Strata T 16Mb id: 0000527A Boot Done Set baud... 921600 Set baud Done Check flash... Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware flash: 89881200010001:89881200000000 error: no any expected answer error: flash write error: 01000000:00020000 Write Fail Finished, time used: 68 sec Remove/Install battery now ! i am using gprs cable i know cable is good because i use the same cable to flash pantech 1410 without problems BR Gee4234 |
12-23-2008, 17:58 | #14 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, It is no a cable problem for sure, cable is good. Please, try to flash this phone with HModule.exe, try to select "Hercules 16M" type. Please, post log here. Let's see results. |
z240 cant flash bad answer any idea ? | Formingus | Z3X-Team Products | 9 | 03-09-2010 07:56 |
610i upgrade cid ok but cant flash and unlock | /\/\A/\/| | SETool2 | 3 | 03-15-2009 19:51 |
i cant flash and unlock this u880 | F@RUK S | FuriousGold | 9 | 09-06-2007 15:41 |
Lead, any news about db2020 flashing and unlocking? | MG77 | Cruiser Suite | 3 | 06-06-2006 15:42 |
cant flash and connect 902SH, need help | y2j007jp | Cruiser Suite | 7 | 07-11-2005 11:15 |
