04-12-2011, 12:08 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Egypt Age: 41
Member: 153397 Status: Offline Sonork: 113032 Thanks Meter: 372 | i cant read any flash fiel or eeprom module v3.29 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:3103:000D status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:FFBFFF00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: EC240200000000:FFBFFF00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #02 in region #00... flash: EC240200000000:FFBFFF00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #03 in region #00... flash: EC240200000000:FFBFFF00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC240200000000:FFBFFF00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: EC240200000000:FFBFFF00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 it's time to stop: FFBFFFBFFFBFFFBFFFBFFFBFFFBFFFBFFFBFFFBFFFBFFFBF number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: _ffs... warning: wrong cs at 0x00E08C00, retry... warning: wrong cs at 0x00E08C00, retry... warning: wrong cs at 0x00E08C00, retry... warning: wrong cs at 0x00E08C00, retry... warning: wrong cs at 0x00E08C00, retry... warning: wrong cs at 0x00E08C00, retry... warning: wrong cs at 0x00E08C00, retry... warning: wrong cs at 0x00E08C00, retry... warning: wrong cs at 0x00E08C00, retry... error: too many retries during read operation Probably errors exist during flash read operation. Do you want to repeat read operation ? error: wrong answer: 98 Probably errors exist during flash read operation. Do you want to repeat read operation ? warning: wrong cs at 0x00E00000, retry... warning: wrong cs at 0x00E00000, retry... warning: wrong cs at 0x00E00000, retry... warning: wrong cs at 0x00E00000, retry... warning: wrong cs at 0x00E00000, retry... warning: wrong cs at 0x00E00000, retry... warning: wrong cs at 0x00E00000, retry... warning: wrong cs at 0x00E00000, retry... warning: wrong cs at 0x00E00000, retry... error: too many retries during read operation Probably errors exist during flash read operation. Do you want to repeat read operation ? aborted by user error: incorrect ffs buffer size Finished, time used: 4 min 23 sec Remove/Install battery now ! |
04-12-2011, 12:33 | #2 (permalink) |
Member: 541591 Status: Online Sonork: 100.1611509 Thanks Meter: 7,361 | What's the problem with the phone? Looks like either there is hardware fault or flash chip is completely erased. Try to read detailed information. Wr. |
04-16-2011, 11:27 | #11 (permalink) |
Member: 153397 Status: Offline Sonork: 113032 Thanks Meter: 372 | after some change COM23 [Serial2] selected module v3.29 Device: Autodetect 6253 NOR Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00C0]: 0098:009E00000000 [TOSHIBA] TC58FYM7T8C chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00020000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: L50MM01.9.52.1.1T09M1021_M700 detect NOR info... number of areas/bytes to read: 1:00040000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: JWT_Z137B_301_PCB01_GPRS_MT6253_S00.L50MM01_9_52_1 _1T09M1021_M700.BIN project-id: L50MM01.9.52.1.1T09M1021_M700, 00000000 code offset: 00000000 ffs offset/size [02]: 00E00000/00200000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.3.29, database date: 04.04.2011): JWT_Z137B_301_PCB01_GPRS_MT6253_S00.L50MM01_9_52_1 _1T09M1021_M700.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== area size: 14Mb number of areas/bytes to read: 1:00E00000 reading (HW_STORAGE_NOR)... file saved: L:\Box\infinity\flashes\الصينى\JWT_Z137B_301_PCB01 _GPRS_MT6253_S00.L50MM01_9_52_1_1T09M1021_M700__fi rmware_20110416-122803.B0M.bin Disconnect... done Finished, time used: 4 min 16 sec Remove/Install battery now ! his file https://rapidshare.com/files/4576749...122803.B0M.bin and iwill try more Last edited by amralkareem; 04-16-2011 at 11:34. |
04-16-2011, 14:21 | #13 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! there is only one way to improve functionality. find and use good drivers for Prolific USB to com converter which is used in your box. If i am not mistaken we had good drivers on our support site |
04-19-2011, 15:23 | #15 (permalink) |
Member: 153397 Status: Offline Sonork: 113032 Thanks Meter: 372 | i install os and setup this driver PL2303_Prolific_DriverInstaller_v110.exe and work good New firmware found (v.3.30, database date: 17.04.2011): JWT_Z150B_001_PCB01_GPRS_MT6225_S00.LB0MM10_8_32_1 _1T09M1221_M511.BIN COM4 [ProlificSerial2] selected module v3.30 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:AD03:000B status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent ==================== New firmware found (v.3.30, database date: 17.04.2011): JWT_Z150B_001_PCB01_GPRS_MT6225_S00.LB0MM10_8_32_1 _1T09M1221_M511.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 05 sw version: JWT_Z150B_001_PCB01_GPRS_MT6225_S00.LB0MM10_8_32_1 _1T09M1221_M511.BIN project-id: LB0MM10.8.32.1.1T09M1221_M511, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (05) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: JWT_Z150B_001_PCB01_GPRS_MT6225_S00.LB0MM10_8_32_1 _1T09M1221_M511__fullflash... file saved: L:\Box\infinity\flashes\الصينى\GFIVE\h610\JWT_Z150 B_001_PCB01_GPRS_MT6225_S00.LB0MM10_8_32_1_1T09M12 21_M511__fullflash_20110419-025117.B0M.bin Finished, time used: 7 min 55 sec Remove/Install battery now ! flash file https://rapidshare.com/files/4581859...025117.B0M.bin thx for help |
The Following User Says Thank You to amralkareem For This Useful Post: |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
