08-22-2007, 03:29 | #1 (permalink) |
Junior Member Join Date: Sep 2005 Location: ThaiLanD Age: 37
Member: 184581 Status: Offline Thanks Meter: 0 | I can't Read information on N97i because Pin out not sure N97i This Phone is User code change I try to use N95(T98) Pin out (because It's connector 2*6 mini same) 1. TX 2. RX 6. GND 5. connect to pin 12 12. connect to pin 5 It's True ??? Please show me Pin out for N97i Thank's Infinity The best |
08-22-2007, 10:15 | #2 (permalink) |
Product Supporter Join Date: Mar 2005 Age: 44
Member: 128745 Status: Offline Thanks Meter: 16,936 | to find pinout for a chinese phone First you must find Gnd .. detailed description to find this can be found here http://forum.gsmhosting.com/vbb/showthread.php?t=433447 After u find gnd follow the steps below How to find pinout for unknown model: In most cases you need to know Gnd, Rx, Tx pins for flash/unlock operations. What do do if you don't have cable or you have new phone model: 1. find Gnd pin (it's required step, you can't continue until you will know Gnd pin location) 2. find Charge pins (it's optional step, just to save your time during future research) 3. find +Battery pins (it's optional step, just to save your time during future research) 4. connect cable Gnd to phone Gnd 5. try to connect cable Rx/Tx wires to all phone contacts one by one (except Gnd, Charge, +Battery pins) and try to read flash from phone 6. if flash read procedure can start this means that pinout found Ok and you can make other operations Note about "Chinese models": a lot of different phones with the same name exist on market (as well as many different name phones with the same pinouts), so, if you see in our "cable selector" wrong pinout for "Chinese models"it's good idea to find correct pinout acording to above instruction and send found pinout information with full text from phone back label to [email protected] |
huawei c2607 pin out not detect pinfinder | somonahmed | Infinity-Box | 7 | 02-23-2010 21:17 |
i can't read pdf on my n73 | gragoh | Nokia Base Band 5 ( BB-5 ) | 1 | 09-26-2007 08:17 |
Was able to read information from my M600i, but can not unlock it. | Glitterfang | KULANKENDI Server | 4 | 07-12-2007 03:47 |
Was able to read information from my M600i, but can not unlock it. | Glitterfang | KULANKENDI Server | 2 | 07-12-2007 01:51 |
Can't Use TotalFlasher on C25 becaus Executing Boot Sequence | UnlockHeaven | x1x to x45/x50 | 1 | 05-31-2001 11:04 |
