06-01-2011, 20:43 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: india Age: 37
Member: 1146038 Status: Offline Thanks Meter: 196 | i can't understand my problem.............. sorry but just info sir : ( with gpg dragan ) i will try to tracker option so my set on with company sound but plane display now i will try to read nv item but same problem .... Brand : Pagaria modal name : Qwerty Blaster read hear log Code: ==== [6/1/2011 8:28:51 PM] ==== COM25 [Serial2] selected module v3.31 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:0D03:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent ==================== New firmware found (v.3.31, database date: 29.05.2011): REBOUND25_08B_PCB01_GPRS_MT6225_S00.N_V589_Y30M10_0201_08B0912M_1_2D100510F01.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 07 sw version: REBOUND25_08B_PCB01_GPRS_MT6225_S00.N_V589_Y30M10_0201_08B0912M_1_2D100510F01.BIN project-id: N.V589.Y30M10.0201.08B0912M.1.2D100510F01, 00000000 code offset: 00000000 ffs offset/size [01]: 00E80000/00180000 rom info structure: [standard] type (07) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E80000 standard ffs/eeprom offset confirmed: 00E80000 detecting ffs/eeprom size... ffs/eeprom size: 00180000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E80000-00FFFFFF firmware area: 00000000-00E7FFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: REBOUND25_08B_PCB01_GPRS_MT6225_S00.N_V589_Y30M10_0201_08B0912M_1_2D100510F01__fullflash... file saved: C:\Documents and Settings\Janki\Desktop\REBOUND25_08B_PCB01_GPRS_MT6225_S00.N_V589_Y30M10_0201_08B0912M_1_2D100510F01__fullflash_20110601-203620.B0M.bin Finished, time used: 42 min 35 sec Remove/Install battery now ! Loading file v.02... REBOUND25_08B_PCB01_GPRS_MT6225_S00.N_V589_Y30M10_0201_08B0912M_1_2D100510F01__fullflash_20110601-203620.B0M.bin loaded usb bootloader (file) is absent rom info ver: 07 sw version: REBOUND25_08B_PCB01_GPRS_MT6225_S00.N_V589_Y30M10_0201_08B0912M_1_2D100510F01.BIN project-id: N.V589.Y30M10.0201.08B0912M.1.2D100510F01, 00000000 code offset: 00000000 ffs offset/size [01]: 00E80000/00180000 rom info structure: [standard] type (07) TCL-ID is absent firmware date/time: 2010-05-10 17-24 hw1: REBOUND25_GEMINI_HW hw2: GEMINI_REBOUND25_08B Code: === [6/1/2011 9:13:40 PM] ==== COM25 [Serial2] selected module v3.31 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware REBOUND25_08B_PCB01_GPRS_MT6225_S00.N_V589_Y30M10_0201_08B0912M_1_2D100510F01__fullflash_20110601-203620.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:5303:0000 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent ==================== New firmware found (v.3.31, database date: 29.05.2011): REBOUND25_08B_PCB01_GPRS_MT6225_S00.N_V589_Y30M10_0201_08B0912M_1_2D100510F01.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 07 sw version: REBOUND25_08B_PCB01_GPRS_MT6225_S00.N_V589_Y30M10_0201_08B0912M_1_2D100510F01.BIN project-id: N.V589.Y30M10.0201.08B0912M.1.2D100510F01, 00000000 code offset: 00000000 ffs offset/size [01]: 00E80000/00180000 rom info structure: [standard] type (07) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E80000 flash: 98000300000001:2AEA0000000000 checking area [00000000]: 00080000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E80000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00180000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E80000-00FFFFFF firmware area: 00000000-00E7FFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: REBOUND25_08B_PCB01_GPRS_MT6225_S00.N_V589_Y30M10_0201_08B0912M_1_2D100510F01__ffs... file saved: C:\InfinityBox\ChineseMiracle\REBOUND25_08B_PCB01_GPRS_MT6225_S00.N_V589_Y30M10_0201_08B0912M_1_2D100510F01__ffs_20110601-211457.B0E.bin flash: 98000300000001:2AEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... done detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: 98000300000001:2AEA0000000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 10 min 25 sec Remove/Install battery now ! Code: ==== [6/1/2011 9:35:35 PM] ==== COM2 [VCP0] selected module v3.31 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: erase whole flash chip ffs/eeprom backup enabled, it may takes several minutes ! operation aborted COM25 ready WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== [6/1/2011 9:36:43 PM] ==== COM25 [Serial2] selected module v3.31 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: erase whole flash chip ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:5303:0000 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent ==================== New firmware found (v.3.31, database date: 29.05.2011): REBOUND25_08B_PCB01_GPRS_MT6225_S00.N_V589_Y30M10_0201_08B0912M_1_2D100510F01.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 07 sw version: REBOUND25_08B_PCB01_GPRS_MT6225_S00.N_V589_Y30M10_0201_08B0912M_1_2D100510F01.BIN project-id: N.V589.Y30M10.0201.08B0912M.1.2D100510F01, 00000000 code offset: 00000000 ffs offset/size [01]: 00E80000/00180000 rom info structure: [standard] type (07) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E80000 flash: 98000300000001:2AEA0000000000 checking area [00000000]: 00080000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E80000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00180000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E80000-00FFFFFF firmware area: 00000000-00E7FFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: REBOUND25_08B_PCB01_GPRS_MT6225_S00.N_V589_Y30M10_0201_08B0912M_1_2D100510F01__ffs... file saved: C:\InfinityBox\ChineseMiracle\REBOUND25_08B_PCB01_GPRS_MT6225_S00.N_V589_Y30M10_0201_08B0912M_1_2D100510F01__ffs_20110601-213758.B0E.bin flash: 98000300000001:2AEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... chip formatting... flash: 98000300000001:2AEA0000000000 Erase: chip 1 of 1 Finalization Done Finished, time used: 2 min 49 sec Remove/Install battery now ! Loading file v.02... REBOUND25_08B_PCB01_GPRS_MT6225_S00.N_V589_Y30M10_0201_08B0912M_1_2D100510F01__fullflash_20110601-203620.B0M.bin loaded usb bootloader (file) is absent rom info ver: 07 sw version: REBOUND25_08B_PCB01_GPRS_MT6225_S00.N_V589_Y30M10_0201_08B0912M_1_2D100510F01.BIN project-id: N.V589.Y30M10.0201.08B0912M.1.2D100510F01, 00000000 code offset: 00000000 ffs offset/size [01]: 00E80000/00180000 rom info structure: [standard] type (07) TCL-ID is absent firmware date/time: 2010-05-10 17-24 hw1: REBOUND25_GEMINI_HW hw2: GEMINI_REBOUND25_08B blinking time my set display show complete after flash my display show plane |
06-02-2011, 09:13 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Make sure that the firmware version that you write is same as that was in your phone before format. Also read eeprom from working set and try to write it to your faulty phone. Wr. |
06-03-2011, 08:29 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! if first log which you posted is Read from good working phone, and second one where you writing it is Writing to faulty- then both flash files version do match. This firmware has no security protection. Also you tried after full flash erase.... I have no more ideas what to try... it must work... check phone's battery voltage |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
