12-29-2006, 12:55 | #1 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 42
Member: 170469 Status: Offline Thanks Meter: 6 | i can't unlock c118 i use x60 cable ,the F-bus switch is up and i use left usb input. when i click at user code/phone lock this message appear: COM8 selected Device: C113(a),C114,C115,C116,C117,C118 Press and HOLD Power button... Err: bad connection but when i press and HOLD power button ,my c118 turn on and RX led blinks but TX led stays off please help me. |
12-29-2006, 14:31 | #4 (permalink) |
No Life Poster Join Date: Feb 2005 Age: 43
Member: 121662 Status: Offline Thanks Meter: 39 | frnd do uninstall yor drivers n install again..den select com port den connect yor box wid com cable n power cable both..switch up on F bus den put yor cable in left side yor fone shuld be on..jst press sp locks bar n follow da instructionsyor fone vil be unlock..100% tested |
12-29-2006, 14:39 | #6 (permalink) | |
No Life Poster Join Date: Nov 2005 Location: .:GSM WORLD:.
Member: 203158 Status: Offline Sonork: 100.1592032 Thanks Meter: 358 | Quote:
01-09-2007, 12:34 | #7 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 39
Member: 170684 Status: Offline Thanks Meter: 19 | How to flash motorola c168 with infinity ?????? Iam not able to flash c168 COM3 selected Device: C168 Checking data, wait... Action: Unlock Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: HW ver: Check Flash Done Check Parameters... detecting device parameters... Err: this version is not supported yet. read flash and send to support. Check Parameters Fail Finished, time used: 120 sec Remove/Install battery now ! All read this file how to send Backup_full_part_1_of_1_2007-1-9_16-34-13.69X.bin . |
01-09-2007, 12:50 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | if you want to flash C168 you need to press "Flash" button in Moto02 module, not "Unlock" and not "Prepare" button. also, go to www.infinity-box.com and download latest Moto02 module. |
how can i unlock c118 | xtremeburaq | Motorola Hardware Repair | 6 | 07-12-2007 07:26 |
How to unlock c118 | 79mobile | Ultima Box Light | 14 | 03-10-2007 06:54 |
Unlocking C118 | arorasatishkuma | Motorola ODM | 3 | 11-07-2006 10:04 |
Unlock c118 using p2k | LHOT | Motorola P2k | 3 | 09-08-2006 18:24 |
unlock c118 | mftah | Motorola ODM | 3 | 08-01-2006 07:52 |
