Old 08-04-2005, 13:20   #1 (permalink)
flechazo's Avatar
Member: 39250
Thanks Meter: 64
Angry i Can't Unlock E101 With Infinity
hi
i try with all cable G50 ( i cut plastic ) T191 X60.. with 5V without 5V and Phone stil Not detected ... Phone is New
some can help m
ReGards .. Faisal !!
Old 08-04-2005, 13:28   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,290
Hello,
Please, cut plastic more and to be sure that connector fit into E101 completely.
You need to use cable with "G50" mark. No need to use T191/X60 cables.
Use our UniBox, connect it to PC via USB, connect cable into left RJ-45 slot.
Old 08-04-2005, 13:34   #3 (permalink)
flechazo's Avatar
Member: 39250
Thanks Meter: 64
Angry
i cut more plastic connector fit into E101 but the phone still not detected ..
with 5V or Not ?
Old 08-04-2005, 14:43   #4 (permalink)
Member: 65795
Thanks Meter: 11
I have same problem with NEC e101 please help me
Old 08-04-2005, 16:34   #5 (permalink)
Member: 130995
with 5V or Not ?
Hi,
What do you mean 5V ? What cable you try to use ?
If you use our cables you don't need any external power for cable.
Please, describe exactly what are you doing.
And some advices:
1. Check COM port selection.
2. Do you see any LED activity on unibox when you press "Unlock" button ? Green LED have to blink very fast after you press "Unlock" button.
3. Give me Log file or text from Log window. This can helps to solve your problem.
You can get more information about this here:
"x300 problem"
Old 08-04-2005, 19:53   #6 (permalink)
flechazo's Avatar
Member: 39250
Thanks Meter: 64
Originally Posted by InfinitySupport
Hi,
And some advices:
"x300 problem"
i try without external power for cable and now i don't have Phone i delete all Logs fot E101 ...!!
ReGards Faisal !!
Old 08-04-2005, 19:58   #7 (permalink)
YourPhone's Avatar
Member: 58075
Thanks Meter: 17
I have to squeze the cable in very hard for the whole time during unlocking, once I had to take phone apart and bend pins, I think the cable is about 1/2mm to short
Old 08-04-2005, 21:17   #8 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 461
I don't know why u peoples have too many problems
Just use ur COM1 Comport & G50 Cable ( Cable Point Completey IN the Phone )
You can connect the Phone on 1 SHOT .
Its the same way like u connect ur X300 , G50 etc .
Old 08-04-2005, 22:18   #9 (permalink)
Moosani's Avatar
Member: 15866
Sonork: 100.109690
Thanks Meter: 192
@aamir
i unlocked upto 25 pcs with t191 cable
i never tried g50 till now may be its works but t191 works perfectly for me
Old 08-05-2005, 23:58   #10 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 461
Strange
T191 cable not works with This Model.
Check ur Cable name again
Old 08-06-2005, 13:01   #11 (permalink)
Member: 7810
Thanks Meter: 3
I have unlocked E101 without problems with infinity
You must better insert jack connector inside phone
br,
pyroz
Old 08-25-2005, 10:38   #12 (permalink)
Kashif Khan's Avatar
Member: 88016
Thanks Meter: 311
few days ago i purchased infinity and i unlocked two pcs without any problem .
Kashif Khan
Old 08-27-2005, 18:26   #13 (permalink)
damabib's Avatar
Member: 106026
Sonork: 100.77890
Thanks Meter: 127
ur problem is driver make u used ur infinity with universal box ,i have same exprience,just used ur cable ith uni box
now vodafone228fm by zte with counter blocked unlock ok with infinity genci titi 2002 Infinity-Box 2 01-19-2009 12:44
can't unlock w230 with Rocker.Dongle but well unlocked with smartclip ROMAB Rocker Dongle (By Legija) 9 12-30-2008 12:28
can't unlock z320 using infinity pl ruvanw1979 Infinity-Box 8 10-03-2008 13:25
((( why i can't connect J100 with infinity ))) Faisal_Computer Infinity-Box 10 04-30-2007 10:04
i Can't Unlock G51E with Infinity Box flechazo Infinity-Box 1 07-09-2005 14:47
Page generated in 0.39798 seconds with 8 queries
