12-24-2010, 05:43 | #1 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Cambodia
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | I can't unlock ZTE G S213 before i flash it with this firmware ZTE-G-S213_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.KE-KP-BE9D-P109A14V1_0_1B02_2010-11-10_En_Khmer.B0M.bin download from support and then unlock is ok but now not ok this log unlock ok but but phone still lock my phone ZTE-G-S213 imei:86................. Full back up from my phone ZTE-G-S213 search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: ZTE-S213_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.KE-KP-BE9D-P109A14V1_0_1B02__ffs... file saved: C:\Program Files\InfinityBox\MModule\ZTE-S213_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.KE-KP-BE9D-P109A14V1_0_1B02__ffs_20101224-112709.B0E.bin flash: 98009600000000:2AEA0000000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... error: phone is not locked or unknown eeprom Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 98009600000000:2AEA0000000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 1 min 14 sec Remove/Install battery now ! Pls help me. thanks. |
The Following User Says Thank You to 089999945 For This Useful Post: |
12-26-2010, 16:47 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Try to unlock phone with latest MModule v3.71 Try to use different unlock methods: "smart fast" and then if phone still not unlocked - try with "standard" method. |
12-27-2010, 15:50 | #3 (permalink) | |
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | Quote:
i can't still unlock ZTE G S-213 when i unlock with smart fast is ok but not unlock and my phone don't have problem. when i unlock with standard is ok the same smart fast but my phoen show this nvram_sec.c,657,52245 525 on the screen (Hold power if release power button my phone turn off) COM126 [VCP0] selected module v3.71 Device: ZTE-S213 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6C91:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 208848FFFFFFFF:20884800000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb otp offset: 007F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent rom info detection finished rom info ver: 07 sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.KE-KP-BE9D-P109A14V1_0_1B02.BIN project-id: KE-KP-BE9D-P109A14V1.0.1B02, 00000000 code offset: 00000000 ffs offset/size [02]: 006F0000/00110000 rom info structure: [standard] type (07) TCL-ID is absent ffs/eeprom address assigned: 006F0000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: ZTE-S213_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.KE-KP-BE9D-P109A14V1_0_1B02__ffs... file saved: C:\Program Files\InfinityBox\MModule\ZTE-S213_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.KE-KP-BE9D-P109A14V1_0_1B02__ffs_20101227-213938.B0E.bin flash: 208848FFFFFFFF:20884800000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... error: phone is not locked or unknown eeprom Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... ......................... required data found flash: 208848FFFFFFFF:20884800000000 flash: 208848FFFFFFFF:20884800000000 Write: area 1 (pass 1) ....... area 1 patch applied Ok detecting parameters to apply patch area 2... ............... required data found flash: 208848FFFFFFFF:20884800000000 flash: 208848FFFFFFFF:20884800000000 Write: area 2 (pass 1) ................. area 2 patch applied Ok Special operation Done ====> Write ... flash: 208848FFFFFFFF:20884800000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 1 min 39 sec Remove/Install battery now ! Pls help me. thanks. | |
12-28-2010, 22:44 | #4 (permalink) | |
No Life Poster Join Date: Dec 2008 Location: some were in my head Age: 42
Member: 922273 Status: Offline Sonork: 100.1583612 Thanks Meter: 119 | re Quote:
http://forum.gsmhosting.com/vbb/f296...4/#post6751762 | |
12-29-2010, 05:27 | #5 (permalink) |
Freak Poster Join Date: Jan 2009 Location: Cambodia Age: 39
Member: 959779 Status: Offline Sonork: 100.1604117 Thanks Meter: 80 | for me after flash ZTE-G-S213_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.KE-KP-BE9D-P109A14V1_0_1B02_2010-11-10_En_Khmer.B0M.bin phone work but even if put original sim it unknown. i don't know why???? help me please |
12-29-2010, 07:56 | #6 (permalink) | |
ur problem is solved. i tested 100% pls good luck 4 u. | |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
