Old 12-12-2005, 18:46   #1 (permalink)
Member: 82155
Thanks Meter: 33
i finally revive x300 but camera not working
i finally revive x300 but camera not working the camera just the camera icon will be there no picture any solution
Old 12-12-2005, 18:47   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
What was with your phone before ?
Old 12-12-2005, 18:52   #3 (permalink)
Member: 82155
Thanks Meter: 33
it was dead not powering
Old 12-12-2005, 19:07   #4 (permalink)
Member: 130995
flash main+lp+map with "erase ffs" checked. if not helps then check phone hardware.
Old 12-12-2005, 19:13   #5 (permalink)
Member: 82155
Thanks Meter: 33
ok i will try that.............................................. ..
Old 02-02-2006, 18:35   #6 (permalink)
Burnt Cobba's Avatar
Member: 11325
Thanks Meter: 266
just met 2 X300.....
1. one was when sim card inserted it wont switch on
2. speaker problem
flashed both. both "worked" ok. both have the camera not working now. the 2nd one was working ok according to client.
really weird
Old 02-02-2006, 19:04   #7 (permalink)
Member: 130995
Hi,
What is the problem with camera exactly ?
What firmware was flashed ?
You can try to flash latest firmware. if not helps, try to flash older one.
Old 02-02-2006, 19:07   #8 (permalink)
Member: 11325
Thanks Meter: 266
the camera icon is shown... once chosen the phone will jam. alternatively pressing the camera button by the side will jam the phone too.
i am using these files....
X300_041_MAIN[1].04M.bin
X300_041_MAP_Du_Fr_De_Ru.04F.bin
as regards language i left it as it was.
will retry with the suggestion above and inform back.
thanks for helping and supporting mate
Old 02-02-2006, 19:39   #9 (permalink)
Member: 130995
Also check hardware: connection camera - PCB. it's easy to damage this connection during open/close phone.
Old 02-02-2006, 22:39   #10 (permalink)
Member: 11325
Thanks Meter: 266
tried MAIN+MAP+LP+EEP and Erase FFS
still the same
seems it is not a software problem.... at this stage.pressing the camera the phone just jams for some seconds and then returns back to the menu. while the screen is open the keys can be heard when pressed too.
n95 key not working and camera not working kkio Nokia Hardware & Hardware Repair 16 11-25-2011 10:32
Soft bank 820sc unlock ok but camera not working ehsas_ghum UST Pro II 0 12-08-2009 09:42
k800 camera video ok but camera not work mouradb3 Sony Ericsson Hardware Repair 1 06-14-2009 16:43
6070 menu key not work. change key ic but still not working timopmass Nokia Hardware & Hardware Repair 5 08-10-2008 22:14
Page generated in 0.17750 seconds with 9 queries
