Old 06-24-2019, 17:17   #1 (permalink)
drjaved_akhter's Avatar
Member: 585807
Thanks Meter: 781
i have 5 clone sat 3310 but flash not work other set
KEYTAK60A_M005_CSD_PCB01_gprs_MT6260_S00.M005_COST DOWN_ALL_1019_V01
clone nokia 3310.i have 5 set and work only one phone.i read working phone and flashed other not workin phone.set on but menu not open. i upload working file by file uploade.please help me ....
Old 06-24-2019, 17:43   #2 (permalink)
Member: 585807
Thanks Meter: 781
****************************/file/5g9vj...9_V01.rar/file
for member..................................
https://www.4shared.com/photo/MHp-Uz...10_mt6260.html
The Following User Says Thank You to drjaved_akhter For This Useful Post:
Old 06-24-2019, 19:03   #3 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Make Format FS operation and check again.
Old 06-25-2019, 06:31   #4 (permalink)
Member: 585807
Thanks Meter: 781
i already format but menu not avaiable............................
Old 06-25-2019, 06:50   #5 (permalink)
Member: 798811
Sonork: astrong
Thanks Meter: 16
its a already format and use to box............
Br.
Old 06-25-2019, 07:05   #6 (permalink)
Member: 585807
Thanks Meter: 781
Br.
what you mean.............................................. .
Old 06-25-2019, 07:08   #7 (permalink)
Member: 585807
Thanks Meter: 781
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 14 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6260_S0000
BB_CPU_SN : BA82C42A3C85A548C581D6A17313D3F9
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
InitRes : 00000000
DEV[0] : C800 6000 1800 0000
DEV[1] : 0000 0000 0000 0000
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00F4 , [GigaDevice] GD25LQ128
[0] : FLASH_DIE : 00C8 0060 0018 0000
[0] : FLASH_LEN : 0x01000000
SDS_INFO : 0x00FFE000 , 0x00002000
INT_RAM : 0x0000D000
EXT_RAM : 0x00800000
File_Info : KEYTAK60A_M005_CSD_PCB01_gprs_MT6260_S00.M005_COST DOWN_ALL_1019_V01.bin
FileVersion : M005_COSTDOWN_ALL_1019_V01
Flash now
Erase region , wait ...
Write data , wait ...
Write : KEYTAK60A_M005_CSD_PCB01_gprs_MT6260_S00.M005_COST DOWN_ALL_1019_V01.bin
Done!
Elapsed: 00:03:05
Reconnect Power/Cable!
after format logo change but menu not available..........
Old 06-25-2019, 10:42   #8 (permalink)
JayDi's Avatar
Member: 462970
All clones are different can be. Do you make backup from them before flashing?
Old 06-25-2019, 11:08   #9 (permalink)
Member: 585807
Thanks Meter: 781
i have only working phone backup witch i upload server and public..................
other 4 handset menu not available condition .
Old 12-09-2019, 13:29   #10 (permalink)
awanbrother's Avatar
Member: 2505147
Thanks Meter: 183
Angry
same here.....................................
Old 02-05-2020, 14:05   #11 (permalink)
Member: 1824929
Thanks Meter: 99
KEYTAK60A_M005_CSD_PCB01_gprs_MT6260_S00.M005_LANG 2_COSTDOWN_1115_V02
need this file
Old 08-29-2020, 11:21   #12 (permalink)
K-B MOBILE's Avatar
Member: 2574306
Thanks Meter: 343
Today i Have recieve Same Model Problem Menu Not Available I Have Make backup then do Format after Format Logo Change and Problem not Solve
then i write orignal backup file flashing stuk on 71% Now set dead Plz Help
Old 10-31-2020, 12:20   #13 (permalink)
Member: 1164608
Sonork: 100.1650273
Thanks Meter: 105
gift for you
http://www.mediafire.com/folder/l8ub...prs_MT6260_S00
Old 11-01-2020, 14:44   #14 (permalink)
Member: 130995
Thanks Meter: 35,227
If write stuck at the same % always it may be hardware problem (f.e. dead flash chip)
Old 11-01-2020, 14:45   #15 (permalink)
Member: 130995
Originally Posted by aquariesirfan View Post
Thansk for link.
Is it well working tested file ?
The Following User Says Thank You to InfinitySupport For This Useful Post:
Page generated in 0.20556 seconds with 8 queries
