03-20-2008, 22:25 | #1 (permalink) |
Freak Poster Join Date: Jan 2008 Location: LiByA
Member: 693427 Status: Offline Thanks Meter: 17 | i have problem with anycool i have anycool with some problem when i flash phone with other flash is not like flash in phone not work i'm downlod orignal flash from supprt is same thing is log ==== log opened: [3/20/2008 5:41:39 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v2.33 S/N: 384E:010E Wait... Device: Autodetect 6205-6227 NOR Done COM3 ready WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? COM3 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 18 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? COM3 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 5 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? COM3 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:B44E:CE83 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.850F9B50.[E553_Z14F8V70D_E553_GPRS_MT6226_S01.01_1.BIN_331D0 5CE].rpl identification#1 detection finished device-id: 850F9B50 identification#1 protocol ver: 04 ver. sw1: E553_Z14F8V70D_E553_GPRS_MT6226_S01.01_1.BIN ver. sw2: E553_Z14F8V70D.01.1, 31FAE2CC ffs offset/size: 00800000/001FF000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00800000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 Detected eeprom/ffs address is non-standard: 00E00000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00E00000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[E553_Z14F8V70D_E553_GPRS_MT6226_S01.01_1.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom[E553_Z14F8V70D_E553_GPRS_MT6226_S01.01_1.BIN]_20080320-174623.B0E.bin flash: EC257E25082501:29EA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: EC257E25082501:29EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _850F9B50_E553_Z14F8V70D_E553_GPRS_MT6226_S01.01_1 .BIN_331D05CE_20080320-174650.B0X.bin Finished, time used: 212 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! ==== log opened: [20/03/2008 08:18:59 ص] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v2.07 S/N: 384E:010E Wait... Device: Autodetect 6205-6227 NOR Done Loading file v.02... Anycool-D66+_E553_K10F8_E553_GPRS_MT6226_S01[1].00_0_16m_En_Ru_Fr_Es_De_Th_Vn_Tr_Ar.B0M.bin loaded identification#1 protocol ver: 04 ver. sw1: E553_K10F8_E553_GPRS_MT6226_S01.00_0.BIN ver. sw2: E553_K10F8.00.0 You have loaded file with security features enabled. Languages: En Ru Fr Es De Th Vn Tr Ar COM3 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: write NOR flash "smart write" active write: Firmware skip: Customization skip: Language Pack skip: Eeprom/ffs Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... chip: 0031:B44E:CE83 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF reading [eeprom]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom_200 80320-082222.B0E.bin flash: EC257E25082501:29EA0000000000 Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 Ok security area backup saved: id.850F9B50.[E553_Z14F8V70D_E553_GPRS_MT6226_S01.01_1.BIN_331D0 5CE].rpl New firmware detected: E553_Z14F8V70D_E553_GPRS_MT6226_S01.01_1.BIN - make "Repair security area" operation - send "backup_system_log_..." file to support - make "Read full flash" operation - send flash backup file(s) to support - include in your e-mail full text from phone back label (phone name etc.) identification#1 detection finished device-id: 850F9B50 identification#1 protocol ver: 04 ver. sw1: E553_Z14F8V70D_E553_GPRS_MT6226_S01.01_1.BIN ver. sw2: E553_Z14F8V70D.01.1 ffs offset/size: 00800000/001FF000 detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.850F9B50._E553 _K10F8_E553_GPRS_MT6226_S01.00_0.BIN_D6B615EE_.rpl warning: unknown identification#1 structure: E553_K10F8_E553_GPRS_MT6226_S01.00_0.BIN_D6B615EE error: Unknown firmware, user action required: 1. download latest software from support area and try again ! 2. if no still luck follow the next procedure: - find good working phone with the same firmware: E553_K10F8_E553_GPRS_MT6226_S01.00_0.BIN - make "Read detailed information" operation - send "backup_system_log_..." file to support - make "Read full flash" operation - send flash backup file(s) to support - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update You can flash phone now but can't finalize it. In most cases phone can NOT power-on normally. Do you want to write flash anyway ? file saved: backup_system_log_850F9B50_E553_Z14F8V70D_E553_GPR S_MT6226_S01.01_1.BIN_331D05CE_20080320-082252.B0X.bin Area: Firmware flash: EC257E25082501:29EA0000000000 Write: Firmware Write Done file saved: backup_system_log_850F9B50_E553_Z14F8V70D_E553_GPR S_MT6226_S01.01_1.BIN_331D05CE_20080320-082835.B0X.bin Finished, time used: 519 sec Remove/Install battery now ! Loading file v.02... Anycool-D66_E553_Z14F8V70D_E553_GPRS_MT6226_S01[1].01_1_16m_En_Ru_Fr_Es_De_Th_Vn_Tr_Ar.B0M.bin loaded identification#1 protocol ver: 04 ver. sw1: E553_Z14F8V70D_E553_GPRS_MT6226_S01.01_1.BIN ver. sw2: E553_Z14F8V70D.01.1 You have loaded file with security features enabled. Languages: En Ru Fr Es De Th Vn Tr Ar COM3 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: write NOR flash "smart write" active write: Firmware skip: Customization skip: Language Pack skip: Eeprom/ffs Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... chip: 0031:B44E:CE83 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF reading [eeprom]... file saved: D:\Chinese Flash\Anycool\backup_eeprom_20080320-083438.B0E.bin flash: EC257E25082501:29EA0000000000 Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 damaged, recalculation required identification#1 detection finished device-id: 850F9B50 identification#1 protocol ver: 04 ver. sw1: E553_K10F8_E553_GPRS_MT6226_S01.00_0.BIN ver. sw2: E553_K10F8.00.0 ffs offset/size: 00800000/001FF000 detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished New firmware detected: E553_Z14F8V70D_E553_GPRS_MT6226_S01.01_1.BIN - make "Repair security area" operation - send "backup_system_log_..." file to support - make "Read full flash" operation - send flash backup file(s) to support - include in your e-mail full text from phone back label (phone name etc.) security area#1 calculation Area: Firmware flash: EC257E25082501:29EA0000000000 Write: Firmware Write Done Finished, time used: 1196 sec Remove/Install battery now ! |
03-22-2008, 12:02 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! can you explane which problem you had with phone what was done with it what was original phone version and which flash files did you try to flash (with what result) |
01-12-2009, 01:43 | #5 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 47
Member: 170822 Status: Offline Thanks Meter: 5 | anycool gc668 how can I master reset or make my anycool work with at&t in the us it seems like the bands or samething is not right it shows emergency only I make sure to put it in the right sim slot and still not working it does get signal but it does not make call only emergency calls please help |
01-13-2009, 16:40 | #6 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
Are you infinity box user? | |
01-13-2009, 16:45 | #7 (permalink) | |
A problem with anycool T318 | nileman | Chinese Models & Cloned Phones | 0 | 02-12-2010 08:13 |
problem with anycool d66+ after flash with infinity | aminem_gsm | Infinity-Box | 3 | 12-10-2008 21:59 |
Problem with Anycool T808 and Pin Out | Bela_Zmija | Infinity-Box | 11 | 06-17-2008 09:35 |
Plz i have problem with anycool LCD is white | motaz alrnuti | Infinity-Box | 4 | 03-30-2008 17:02 |
Still have problem with tia files? I have Tia.pacher! | lotfi17 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 01-14-2001 14:18 |
