11-25-2007, 09:41 | #1 (permalink) |
No Life Poster Join Date: Jul 2006
Member: 308296 Status: Offline Thanks Meter: 152 | i have problem formating cpu6295BA Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6205:8B00]... Connecting, wait... warning: wrong packet cs error: can't finalize test moide Operation failed ! Finished, time used: 23 sec Remove/Install battery now ! |
11-25-2007, 09:46 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Here is instruction that was written especially for you: http:///vbb/showthread.php?t=447277 |
11-25-2007, 09:53 | #3 (permalink) |
Member: 308296 Status: Offline Thanks Meter: 152 | sir i have two set one is zt678 or second is bluetooth 6688 i m format the set with other software but problem is not solve customer says problem came after bluetooth tranfring sir plz give me the solution Thanks in advance |
11-25-2007, 10:35 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Dear Friend, Here is instruction that was written especially for you: http:///vbb/showthread.php?t=447277 |
11-25-2007, 10:38 | #6 (permalink) |
Member: 308296 Status: Offline Thanks Meter: 152 | sorry sir if u dont mind i m try this all method sir after complete format i m srr this meesage Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6205:8B00]... boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: BF7353FFFF0052:FFFFFF00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error flash: SST AMD/Fujitsu std [def 0040x010000 0400x001000] 8Mb detecting chip #01 in region #00... flash: BF7353FFFF0052:FFFFFF00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error flash: SST AMD/Fujitsu std [def 0040x010000 0400x001000] 8Mb detecting chip #02 in region #00... flash: BF7353FFFF0052:FFFFFF00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error flash: SST AMD/Fujitsu std [def 0040x010000 0400x001000] 8Mb detecting chip #03 in region #00... flash: BF7353FFFF0052:FFFFFF00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error flash: SST AMD/Fujitsu std [def 0040x010000 0400x001000] 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud... slowest Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: BF7353FFFF0052:FFFFFF00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error flash: SST AMD/Fujitsu std [def 0040x010000 0400x001000] 8Mb Warning: probably flash chip empty, erased, incorrectly flashed or damaged. What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support with detailed description of problem, attach the next files in your e-mail: 1. E:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. E:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin detecting chip #01 in region #00... flash: BF7353FFFF0052:FFFFFF00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error flash: SST AMD/Fujitsu std [def 0040x010000 0400x001000] 8Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished detecting eeprom area in 1 chip(s)... flash: BF7353FFFF0052:FFFFFF00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error checking area[00000000]: 00000000-007FFFFF... Can't detect eeprom area Do you want to use standard eeprom address: 00700000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard eeprom address selected by user detecting eeprom size... eeprom size: 00100000 eeprom chip: 00 eeprom area: 00000000:00700000-007FFFFF flash: BF7353FFFF0052:FFFFFF00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... formatting... flash: BF7353FFFF0052:FFFFFF00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error error: error# 0000FF3B error: flash erase error: 00700000 error: error# 0000FF3B error: flash erase error: 00700000 error: error# 0000FF3B error: flash erase error: 00700000 error: error# 0000FF3B error: flash erase error: 00700000 error: error# 0000FF3B error: flash erase error: 00700000 Write Fail Finished, time used: 75 sec Remove/Install battery now ! |
Nokia 3110c,6300,5200c... have any format code | pradipbarua | Nokia Hardware & Hardware Repair | 9 | 06-15-2009 09:34 |
Hi To All I Have Problem I Don't Play Video In 9210i I Have A Mm Converter But Can't | Shakeel Communication | Off Topic Zone | 2 | 07-30-2008 17:00 |
i have having problem to select flash file automatically from mt ; pls give ini file | monsterpassword | MT-BOX | 2 | 12-16-2007 18:55 |
i have a new mt bot i have problem | hassangmmm | MT-BOX | 3 | 11-23-2005 20:32 |
Still have problem with tia files? I have Tia.pacher! | lotfi17 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 01-14-2001 14:18 |
