Old 12-26-2009, 18:34   #1 (permalink)
Member: 835033
Sonork: luca
Thanks Meter: 22
I have a problem with Infinity pinfinder on pinout
I have a problem with Infinity pinfinder during search pinout,I can't find auto pinout with pinfinder even 6300 Mt 6225,I tested several phones,I always use RJ45 for any oparetion in infinity Box and it takes me too long to find Tx and RX that's y I like to use pinfinder to save time,so please help me what is wrong with this Infinity pinfinder.
Thanx in adv.
Old 12-27-2009, 20:02   #2 (permalink)
Member: 148515
Thanks Meter: 14,657
hello!
before searching pinout you must do 3 easy steps:
1. Make sure that this is mt62xx MCU based phone.
tip: you can check this by typing *#0044# and pressing green (send) button.
if you will see "language set: english"- you can be sure, that this phone is MT62xx.
Now activate Silent mode in phone by pressing and holding "#".
2. Count number of pins in system connector. After this is done-
pick correspondent cable. For example if you counted 2x6 pins- it is in total 12
so no point to put L14D cable instead of correct one, L12B.
3. Select cable type, connect power crocodiles in the place of battery.
push "Power On!" in software. Now phone is powered with pinfinder power.
Try to switch it On. This is main rule for success pinout search.
(Phone must turn ON)
if it does not turn On- no point to search for pinouts. you will not find it.
Start from modifying your main infinity box to deliver more power to pinfinder.
There is one diode which must be removed and shortcutted.
Open Pinfinder User Manual on Trubleshooting section and see in pictures how this must be done.
after you get phone powered- you are ready to find phone pinout.
press and Hold phone power button and start search.
sfr 111 succefull unloked with infinity+pinfinder noure30 Infinity-Box 5 02-17-2010 11:04
Infinity PinFinder - USB Pinout Detection for SPREADTRUM phones needed ! MasterJey Infinity-Box 6 04-04-2009 21:07
Strange problem with infinity + pinfinder sairat Infinity-Box 10 01-10-2009 17:29
succesfully unlock alcatel s210 with infinity+pinfinder Haouas Infinity-Box 1 07-26-2008 20:33
I have a problem with AT command on X100 & E820 Vadiks SYSOL Platform 0 01-03-2005 04:07
Page generated in 0.39562 seconds with 8 queries
