i mobile 200 dear infinity team, can u help me,how to flash i mobile 200?? |
Hello, As I can see this model is not supporte yet. What is phone CPU chip name ? What is connector type ? |
Its cpu infeninio 7870 Connector 6300 type |
Hello, Please, post here more detailed information about pinout. Also try to read full flash like ZTE-225 and send full flash backup to [email protected] |
I-Mobile 200 : CPU : 7870 / infineon Flash IC : Samsung K5J632CTM-0770 Connector : 2X5(10C) ==> pinfinder i use Pinfinder to find pinout, and this the result : i read full flash use I-Mobile 313 model. |
thanks in advance |
Hello, We have got IMobile-200 backup file, hope to prepare good flash files soon. |
how to flashing i-mobile 200 by infinity,fileflash already to support |
COM7 [VCP0] selected module v1.62 Device: IMobile-313 Checking data, wait... Action: flash write Boot ... loader: standard type: 1 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 0001:0102 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\IMobile-313_eeprom-static_20090222-172452.B1E.bin loading data... wrong database file: C:\Program Files\InfinityBox\Pana01\ulc1_i313_eep65535.cfg error: can't load database v.6310 reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\IMobile-313_eeprom-security_20090222-172454.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: Firmware Writing: Firmware Write Done Finished, time used: 265 sec Remove/Install battery now ! flashing done..i can see log flashing show error can"t load database v6310 after flashing my phone restart:confused: |
COM7 [VCP0] selected module v1.62 Device: IMobile-313 Checking data, wait... Action: flash write Boot ... loader: standard type: 1 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 0001:0102 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\IMobile-313_eeprom-static_20090222-172452.B1E.bin loading data... wrong database file: C:\Program Files\InfinityBox\Pana01\ulc1_i313_eep65535.cfg error: can't load database v.6310 reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\IMobile-313_eeprom-security_20090222-172454.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: Firmware Writing: Firmware Write Done Finished, time used: 265 sec Remove/Install battery now ! flashing done..i can see log flashing show error can"t load database v6310 after flashing my phone restart problem:confused: |
@twentyonecell "database load" error is not critical. What was with your phone before flash ? Why you tried to flash phone ? |
phone came to me dead already...after donwload fileflash to support and flashing phone turn on and restart:D:D what problem:confused: |
