10-16-2008, 12:12 | #1 (permalink) |
Registered User Join Date: Mar 2007 Location: Bandung, Indonesia
Member: 461468 Status: Offline Thanks Meter: 139 | I-mobile 520 format ffs problem I have problem for format i-mobile 520 with infinity MModule, was trying more times. Please explain? Phone's problem could not open SMS, any hide SMS with need security code. Urgent! please reply Regards, |
10-16-2008, 13:03 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Dear Friend, We will be glad to give you an advice after you will make detailed technical explanation of problem. Please, do it, and we will try to help you ASAP. |
10-17-2008, 09:07 | #3 (permalink) | |
Member: 461468 Status: Offline Thanks Meter: 139 | I-mobile 520 format ffs problem Quote:
Dear Sirs, Thanks for your quick reply Herewith logs: COM6 [VCP0] selected module v2.36 Device: I-Mobile-520 Checking data, wait... Action: NAND reset read mode: 01 Boot... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing[6219:8B02:8B01]... CPU: MT6219 CPU: MT6226MA detected chip: 0031241:03E8 high speed disabled boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.020B loader: 3.748.0 NAND: Toshiba TC58DVM92A1FT 512+16 32 pages, 66Mb NAND id: 9876A5C0 page size: 200+10 pages/block: 20 bits i/o: 08 address cycles: 04 blocks: 1000 NOR: 0098:004900000000 [01000000] NAND: 0098:007600A500C0 [04200000] Initialize Done Set baud... 115200 Set baud Done Identification... detect device identification#1... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation reading... reading... reading... reading... reading... reading... reading... reading... security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.03B79 E09.[A7336_26M_06B_PCB01_GPRS_MT6226M_S01.7S7336MY00-001-R1B.BIN_8109E091].rpl identification#1 detection finished error: can't detect ffs address Identification Fail file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_03B79E09_A7336_26M_06B_PCB01_GPRS_MT6226M_S01.7 S7336MY00-001-R1B.BIN_8109E091_20081017-144147.B0X.bin Finished, time used: 80 sec Remove/Install battery now ! May be with this logs u explanation for solution? Thanks & Rgds, ABELL Cellular, Bandung-Indonesia | |
10-17-2008, 20:01 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, 1. run "Chinese Miracle" software 2. select model "6228 NAND" 3. go to "Service" page 4. make format with "whole flash chip" mode |
10-21-2008, 03:05 | #5 (permalink) |
Member: 461468 Status: Offline Thanks Meter: 139 | Hello, We hve try formated still error! Logs: ==== log: [10/20/2008 8:20:12 PM] ==== COM6 [VCP0] selected module v2.64 Device: Autodetect 6228, 6229, 6230 NAND Checking data, wait... Action: erase flash chip Boot... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing[6219:8B02:8B01]... CPU: MT6219 high speed boot disabled CPU: MT6226MA detected chip: 0031241:03E8 high speed disabled boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.020B loader: 3.748.0 NAND: Toshiba TC58DVM92A1FT 512+16 32 pages, 66Mb NAND id: 9876A5C0 page size: 200+10 pages/block: 20 bits i/o: 08 address cycles: 04 blocks: 1000 NOR: 0098:004900000000 [01000000] NAND: 0098:007600A500C0 [04200000] Initialize Done Set baud... 115200 Set baud Done Identification... reading structure area... detecting structure... warning: probably flash chip completely erased, no bootloader found nfi area detection finished: failed error: can't detect nand chip parameters, default values assigned Identification Done Write... formatting... error: code: C080FC3FF8 Write Fail Finished, time used: 78 sec Remove/Install battery now ! Thks & Rgds, |
10-21-2008, 11:45 | #7 (permalink) |
Member: 461468 Status: Offline Thanks Meter: 139 | Hello... Yes, we have try to make but software not working properly only used formate FFS whole flash chip mode-1 SMS only, incoming message save to property folder not Inbox and need some PIN to open SMS. And now the phone could not open MENU due more incoming messages. If you need We will upload BACKUP Flash n EEPROM Thks n regards |
10-21-2008, 15:53 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, It\'s no need to upload backup file due to it can not helps. Try to make format whole flash chip again. In case of problems I think there is a reason to reball or replace NAND flash chip. |
10-22-2008, 09:18 | #9 (permalink) |
Member: 461468 Status: Offline Thanks Meter: 139 | I-mobile 520 format ffs problem Hello, Again we have try to formated \whole flash chip is working sucessfully, just message on private menu not formated After power on the mobile still could not open MENU with simcard inserted, any phone functions working properly except MENU (I mean to make call, keypad etc). And try power on the mobile without simcard MENU working but we try to deleted Message on private menu only "LOADING" not opened. What the problems??? I think this is not NAND flash chip, still Software. Question: Why??? Message on Private Menu not Formated together with \whole flash chip functioning. It is viruses or ???? Thks for your kind reply n attention. Rgrds, |
10-26-2008, 04:15 | #11 (permalink) |
Member: 461468 Status: Offline Thanks Meter: 139 | Hello We have download flash files n re-flash & formated with new module ver 2.38, the phone was working fine. Thks for your nice support. Rgds, ABELL Cellular E-Mail & YM : [email protected] |
10-26-2008, 13:36 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Glad to hear about good results. Also, if you will have more phones with new firmware versions please, read flash and send it to [email protected] so we will be able to upload more files in support area for all users. |
01-11-2009, 10:30 | #13 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Mirpur-1, Dhaka,Bangladesh
Member: 222009 Status: Offline Sonork: 100.1576751 Thanks Meter: 435 | after format with comlete mode set becomes dead previous situation was restarting then I tried with flash with the file given on support site but it gives msg that it may not power up after flash , try with latest module , I have tried with latest module but same result I-mobile 520 cpu -- 6219 pls help , set is now dead |
TV mobile n99i after format ffs no signal | boyaxe | Infinity-Box | 11 | 12-18-2010 16:16 |
Post all your hang samsung mobile, which were solved by format ffs only | khem | Z3X-Team Products | 2 | 02-20-2010 11:31 |
chaina mobile dead after ffs complete format | sajidashraf | Infinity-Box | 3 | 06-06-2009 08:48 |
Problem After Formatting FFS | imran_qasim | Infinity-Box | 4 | 01-05-2008 12:34 |
mobile auto off format ffs | mobilecarerke | Infinity-Box | 2 | 11-10-2007 20:30 |
