09-12-2010, 09:33 | #1 (permalink) |
No Life Poster Join Date: Feb 2010 Location: Pinas
Member: 1243303 Status: Offline Sonork: 1591167 Thanks Meter: 514 | I-Mobile-536 module v3.59 Device: I-Mobile-530 Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:2003:0009 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC227E22632260:18E59F00000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: FOXLINK6225_07B_GEMINI_PCB01_GPRS_MT6225_S00.BM15A 1_B0_02_M01_03_18.BIN project-id: BM15A1.B0.02.M01.03.18, 00000000 code offset: 00000000 ffs offset/size [01]: 01C00000/00400000 rom info structure: [standard] type (04) TCL-ID is absent ffs/eeprom address assigned: 01C00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: I-Mobile-530_FOXLINK6225_07B_GEMINI_PCB01_GPRS_MT6225_S00.B M15A1_B0_02_M01_03_18__ffs... file saved: C:\Program Files\InfinityBox\MModule\I-Mobile-530_FOXLINK6225_07B_GEMINI_PCB01_GPRS_MT6225_S00.B M15A1_B0_02_M01_03_18__ffs_20100912-163058.B0E.bin flash: EC227E22632260:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC227E22632260:18E59F00000000 Finalization Done Finished, time used: 4 min 43 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! format done but phone dead http://www.gsmarena.com/i_mobile_tv_536-2872.php |
09-12-2010, 09:41 | #3 (permalink) |
Member: 1243303 Status: Offline Sonork: 1591167 Thanks Meter: 514 | flashing? you have firmware downloaded today: 0, allowed per day: 25, downloaded total: 143Search results : for /flashfiles/IMobile/ and its subdirectories [ NO RESULTS FOUND ] End of search (0 found) Files Folders Both Go back. |
