Old 04-18-2009, 05:39   #1 (permalink)
Member: 862105
i-mobile 903 how to flash and unlock?
hi everyone,
i got one i-mobile 903 this phone had phone lock code also network lock, tried infinity software can detech the phone but cant do any unlock and usercode reset, infinity support had one file to flash but dont know how to flash, pls advice thanks in advance
Old 04-18-2009, 06:46   #2 (permalink)
notgood's Avatar
Member: 355635
Originally Posted by omnitech View Post
hi everyone,
for remove phone lock code... u can do just format operation
for network lock just press sp-unlock use method : standard
for flash .. just read info firmware the phone... then look in support find the same firmware.... then just flash it, better u read full flash before u flash the phone
regards
notgood
Old 04-18-2009, 09:35   #3 (permalink)
InfinitySupport's Avatar
Member: 130995
hi everyone,
Hello,
How to write flash (upgrade/downgrade firmware, change language):
1. connect cable from box to device
2. run "Infinity-Box Shell" software
3. select required model
4. run required software module
5. select required model (if need)
6. go to software "Settings" page and select COM port
7. go to software "Flash" page and load required files
8. press "Write" button and follow instruction given by software
How to read flash:
7. go to software "Service" page
8. press "Read flash" (or "Read full flash") button and follow instruction given by software
How to unlock (remove sp-lock, provider lock etc.):
8. press "SP-Unlock" button and follow instruction given by software
How to reset/format ffs (reset setting to default values, repair freez/restart etc.):
- at first try to make "safe format" (if this option exist)
- if "safe" option is not works try to make "complete" format (if this option exist)
8. select format mode "safe" or "complete" (if mode is available)
9. press "Reset" or "Format" button and follow instruction given by software
How to flash and unlock with Ub box ? mma Universalbox 5 11-03-2008 05:47
How to flash and unlock C139 with UBL? CRUELTY Ultima Box Light 1 04-07-2007 20:13
How to flash and unlock T630? whiteswang Cruiser Suite 9 05-29-2006 15:50
How to flash and unlock Se T200 kassongo Sony Ericsson 2 03-29-2006 20:21
how to flash and unlock x6x phones fast way? gsmsalers S-Gold Based Phones 0 01-20-2005 11:50
Page generated in 0.22440 seconds with 11 queries
