GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Infinity-Box (https://forum.gsmhosting.com/vbb/f296/)
-   -   I-Moblie CE0889 Always Died (https://forum.gsmhosting.com/vbb/f296/i-moblie-ce0889-always-died-530456/)
dany_kroya81 04-25-2008 16:47
@ infinity support
i have problem with my dead I-Mobile CE0889
after flashing, mobile always die
i need solution to solved my problem
whats wrong sir......????
COM13 selected
Device: I-Mobile CE0889
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: write NOR flash
"smart write" active
"format ffs" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
write: Eeprom/ffs
Boot...
19200 fixed
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
chip: 0031:54BF:B97A
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 98001B0000000A:29EA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
Initialize Done
Set baud...
921600
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw1: ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S-7311-INS0-0-R1B-3.BIN
ver. sw2: 7S-7311-INS0-0-R1B-3, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading [eeprom[ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S-7311-INS0-0-R1B-3.BIN]]...
file saved: C:\Program Files\InfinityBox\MModule\backup_eeprom[ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S-7311-INS0-0-R1B-3.BIN]_20080425-222249.B0E.bin
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Area: Firmware
Write: Firmware
Area: Eeprom/ffs
Write: Eeprom/ffs
Write Done
Finalization...
formatting...
flash: 98001B0000000A:CED27D00000000
Finalization Done
Finished, time used: 217 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
BR,
mr_dany
InfinitySupport 04-25-2008 17:23
Hello,
Press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On.
dany_kroya81 04-25-2008 17:37
Originally Posted by InfinitySupport (Post 3269107)
Hello,
yes sir but after that phone always died,
any solution ????
InfinitySupport 04-25-2008 17:41
What is initial phone state ?
dany_kroya81 04-25-2008 18:08
what is ur means sir ????
coz i dont know
before flashing,phone condiition is dead
in the support only one file
maybe with others file sir ?????
dany_kroya81 04-25-2008 19:01
i-mobile CE0889 Ver.B <--- what is the means sir ????
InfinitySupport 04-25-2008 19:56
Nobody know what is it
coz i dont know
If phone was dead you must check phone hardware.
So open phone, check it's hardware and report about results.
dany_kroya81 04-25-2008 21:03
phone hardwae its OK no problem serious
phone immedietly dead when make a call
so, is the eeprom influence dead phone
im sorry my english is very bad :D :D :D
InfinitySupport 04-26-2008 07:33
Did you tried to make 112 (emergency) call without SIM card ?
What is the results ?
dany_kroya81 04-27-2008 09:45
phone is dead sir .....
can make a call :confused: :confused:
InfinitySupport 04-27-2008 12:18
Explain what is the situation with phone ?
I can't understand is it dead or alive phone.
azi_kewl 04-28-2008 13:05
The same that i Have...maybe someone could explain us.
InfinitySupport 04-28-2008 13:43
Hello,
Please, explain more detailed what is the question and what kind of answer you need.
CxVj 04-30-2008 15:26
phone is dead but can make a call? weird.. bro and very strange man.. :D:confused:
Page generated in 0.13671 seconds with 6 queries
