Old 04-25-2008, 16:47   #1 (permalink)
dany_kroya81's Avatar
Member: 584778
Thanks Meter: 78
Red face I-Moblie CE0889 Always Died
@ infinity support
i have problem with my dead I-Mobile CE0889
after flashing, mobile always die
i need solution to solved my problem
whats wrong sir......????
COM13 selected
Device: I-Mobile CE0889
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: write NOR flash
"smart write" active
"format ffs" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
write: Eeprom/ffs
Boot...
19200 fixed
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
chip: 0031:54BF:B97A
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 98001B0000000A:29EA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
Initialize Done
Set baud...
921600
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw1: ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S-7311-INS0-0-R1B-3.BIN
ver. sw2: 7S-7311-INS0-0-R1B-3, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading [eeprom[ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S-7311-INS0-0-R1B-3.BIN]]...
file saved: C:\Program Files\InfinityBox\MModule\backup_eeprom[ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S-7311-INS0-0-R1B-3.BIN]_20080425-222249.B0E.bin
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Area: Firmware
Write: Firmware
Area: Eeprom/ffs
Write: Eeprom/ffs
Write Done
Finalization...
formatting...
flash: 98001B0000000A:CED27D00000000
Finalization Done
Finished, time used: 217 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
BR,
mr_dany
Old 04-25-2008, 17:23   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,218
Hello,
Press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On.
Old 04-25-2008, 17:37   #3 (permalink)
Member: 584778
Thanks Meter: 78
Originally Posted by InfinitySupport View Post
Hello,
yes sir but after that phone always died,
any solution ????
Old 04-25-2008, 17:41   #4 (permalink)
Member: 130995
What is initial phone state ?
Old 04-25-2008, 18:08   #5 (permalink)
Member: 584778
Thanks Meter: 78
what is ur means sir ????
coz i dont know
before flashing,phone condiition is dead
in the support only one file
maybe with others file sir ?????
Old 04-25-2008, 19:01   #6 (permalink)
Member: 584778
Thanks Meter: 78
i-mobile CE0889 Ver.B <--- what is the means sir ????
Old 04-25-2008, 19:56   #7 (permalink)
Member: 130995
Nobody know what is it
Old 04-25-2008, 19:56   #8 (permalink)
Member: 130995
coz i dont know
If phone was dead you must check phone hardware.
So open phone, check it's hardware and report about results.
Old 04-25-2008, 21:03   #9 (permalink)
Member: 584778
Thanks Meter: 78
phone hardwae its OK no problem serious
phone immedietly dead when make a call
so, is the eeprom influence dead phone
im sorry my english is very bad
Old 04-26-2008, 07:33   #10 (permalink)
Member: 130995
Did you tried to make 112 (emergency) call without SIM card ?
What is the results ?
Old 04-27-2008, 09:45   #11 (permalink)
Member: 584778
Thanks Meter: 78
phone is dead sir .....
can make a call
Old 04-27-2008, 12:18   #12 (permalink)
Member: 130995
Explain what is the situation with phone ?
I can't understand is it dead or alive phone.
Old 04-28-2008, 13:05   #13 (permalink)
Member: 459470
Thanks Meter: 17
The same that i Have...maybe someone could explain us.
Old 04-28-2008, 13:43   #14 (permalink)
Member: 130995
Hello,
Please, explain more detailed what is the question and what kind of answer you need.
Old 04-30-2008, 15:26   #15 (permalink)
CxVj's Avatar
Member: 122712
Thanks Meter: 117
can make a call
phone is dead but can make a call? weird.. bro and very strange man..
E71 and N96 died by normal FBUS flashing!! Cake HWK 2 03-30-2010 08:10
Page generated in 0.56079 seconds with 8 queries
