07-14-2010, 13:27 | #1 (permalink) |
Banned Join Date: May 2004 Location: Mauritius
Member: 64823 Status: Offline Thanks Meter: 437 | I need this FIRMWARE Phone is NOT on !! Nokia E51s But since its NEW firmware i will upload it but the phone is DEAD can you check if the firmware is GOOD?? I have HEAT CPU and RAM still dead make COMPLETE FFS !! Also ! Rapidshare: RapidShare: 1-CLICK Web hosting - Easy Filehosting COM26 [VCP0] selected module v3.15 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:FB03:000F status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished ==================== New firmware detected (v.3.15, database date: 06.06.2010): GXQ25_GEMINI_PCB01_GPRS_MT6225_S00.K2542_JIAHONG_V 04_B11.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info ver: 04 sw version: GXQ25_GEMINI_PCB01_GPRS_MT6225_S00.K2542_JIAHONG_V 04_B11.BIN project-id: K2542_JiaHong_V04_B11, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00080000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detecting ffs/eeprom structure pass 1... ....................... ffs/eeprom: detect std location pass #1... ............................................... ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished detecting firmware version... firmware version: GXQ25_GEMINI_PCB01_GPRS_MT6225_S00.K2542_JIAHONG_V 04_B11.BIN detecting firmware build... .................................................. .............. .................................................. .............. done detecting product-id... .................................................. .............. done detecting languages... ......................................... language parameters detected detected languages: En Ru Fr Es It Id Th Vn Pt Finished, time used: 2 min 33 sec Remove/Install battery now ! |
07-14-2010, 14:21 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | hello! sorry, we dont need damaged firmwares. regarding your problem:try to flash phone with this firmware: flashfiles/ChineseMiracle/_MT6225/GXQ25_GEMINI_PCB01_GPRS_MT6225_S00.K2542_JIAHONG_V 06_B11_18__GXQ-25_16m_En_Ru_Fr_Es_It_Id_Th_Vn_Farsi_Pt_Ar.B0M.bin |
