01-02-2008, 10:10 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: Mobile Phone Repairing
Member: 108747 Status: Offline Sonork: 100.108643 Thanks Meter: 655 | i need flash file w.b.r |
01-03-2008, 11:53 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! now i see... yes, you must find this file. but also, you can try to write all 3 files starting "RATECH28_06A_PCB04_GPRS_MT6228_S02" from our support area and check if they will work also |
01-04-2008, 11:17 | #5 (permalink) |
Member: 108747 Status: Offline Sonork: 100.108643 Thanks Meter: 655 | i will try with these files they will show error given below COM6 selected Device: Autodetect 6228 NAND Checking data, wait... Action: read/check detailed information Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6228:8A02:8A02]... chip: 0031:0000:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.1 loader: 3.1.02 NAND id: ADF1801D page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00AD:00F10080001D [08400000] NOR chip is not installed Initialize Done Set baud... 115200 Set baud Done Identification... reading structure area... detecting structure... source data: page+spare converting data... done 0x00080000 bytes identification#1 protocol ver: 04 ver. sw1: RATECH28_06A_PCB04_GPRS_MT6228_S02.R2000_ML_01_1_0 T02S0824.BIN ver. sw2: R2000_ML_01_1.0T02S0824 ffs offset/size: 02000000/06000000 id-page Ok nfi area detection finished: Ok identification#1 structure: 2nd [enhanced] generation error: unexpected answer: error: unexpected answer: security area#1 damaged, recalculation required identification#1 detection finished Finished, time used: 94 sec Remove/Install battery now ! |
NKTEL A200 flash file in Spider man box need flash file? | >>.123.<< | SpiderMan | 15 | 11-12-2010 16:12 |
E66 nokia need flash file no flash file in support | lilong_lee | Infinity-Box | 11 | 02-07-2010 01:51 |
!!!!! Needed, flash file for 8120 02 sfi file !!! | stemo | FuriousGold | 2 | 03-11-2009 20:08 |
L7i need flash file and boot file | aukonline | Smart-Clip | 3 | 03-10-2009 11:15 |
i need flash file and database file for t190 v 1.71 becuase | nanana | Motorola ODM | 0 | 08-17-2002 11:37 |
