11-29-2008, 11:15 | #1 (permalink) |
Freak Poster Join Date: Jun 2007 Location: S A H I W A L Age: 38
Member: 526737 Status: Offline Thanks Meter: 9 | I need flash file Here log Detailed information OM4 selected module v2.69 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read/check detailed information Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:1903:000B boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:FFBFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:FFBFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:FFBFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:FFBFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: FFBFFFBFFFBFFFBFFFBFFFBFFFBFFFBFFFBFFFBFFFBFFFBF number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: EC257E25082501:FFBFFF00000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E30000 Detected eeprom/ffs address is non-standard: 00E30000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address confirmed by user: 00E30000 detecting eeprom/ffs size... eeprom/ffs size: 001D0000 ffs chip: 00 eeprom/ffs area: 00000000:00E30000-00FFFFFF detecting ffs structure pass 1... .................................................. ....... can't detect fat record name location error: ffs element #1 detection failed detecting ffs structure pass 2... .................................................. ....... can't detect fat record name location error: ffs element #2 detection failed Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Finished, time used: 138 sec Remove/Install battery now ! |
11-29-2008, 22:46 | #7 (permalink) | |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... this warning is mostly comes when phone has h\w pb..(damaged fw..or etc.) but sometimes after formatting ffs completly comes this warning messege again.. disaamble the phone and check on pcb file name... f.ex : E558_... or etc... | |
11-30-2008, 13:39 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, As I can see by other data from log (f.e. it's time to stop: FFBFFFBFFFBFFFBFFFBFFFBFFFBFFFBFFFBFFFBFFFBFFFBF) this phone has damaged or wrong flashed flash chip. I think format can't help in this situation, need to try to flash phone with good flash files and see results. |
NKTEL A200 flash file in Spider man box need flash file? | >>.123.<< | SpiderMan | 15 | 11-12-2010 16:12 |
E66 nokia need flash file no flash file in support | lilong_lee | Infinity-Box | 11 | 02-07-2010 01:51 |
!!!!! Needed, flash file for 8120 02 sfi file !!! | stemo | FuriousGold | 2 | 03-11-2009 20:08 |
L7i need flash file and boot file | aukonline | Smart-Clip | 3 | 03-10-2009 11:15 |
i need flash file and database file for t190 v 1.71 becuase | nanana | Motorola ODM | 0 | 08-17-2002 11:37 |
