-   Infinity-Box (http://forum.gsmhosting.com/vbb/f296/)
-   -   I need flash file china mission islimic mobile (http://forum.gsmhosting.com/vbb/f296/i-need-flash-file-china-mission-islimic-mobile-1207775/)
imdad-ia 02-15-2011 03:49
Totel Mobile 100% Working Only The Holy Quran problem when i open the holy quran menu lcd white show than show audio content error
i have allready use full format but same problem
rom info detection finished
rom info ver: 04
sw version: HEXING25_GEMINI_PCB01_GPRS_MT6225_S00.MM220_MISSIO N_TECH_HK.BIN
project-id: MM220_MISSION_TECH_HK, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
rom info structure: [standard] type (04)
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
firmware area: 00000000-00DFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: HEXING25_GEMINI_PCB01_GPRS_MT6225_S00.MM220_MISSIO N_TECH_HK__ffs...
file saved: D:\Program Files\InfinityBox\ChineseMiracle\HEXING25_GEMINI_P CB01_GPRS_MT6225_S00.MM220_MISSION_TECH_HK__ffs_20 110214-101949.B0E.bin
flash: 98000300000001:18E59F00000000
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 3 min 39 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
FULL READ FLASH FILE HERE
http://rapidshare.com/files/44799166...104929.B0M.bin
imdad-ia 02-15-2011 18:17
plz help me sir InfinitySupport,
imdad-ia 02-17-2011 15:29
InfinityHelp 02-17-2011 20:15
hello!
must be very rare or new firmware.
unfortunately we dont have it in our collection.
you can try to search for same working phone on local market.
read out full backup and use it for flashing your faulty phone.
also i can convert to infinity format BIN file, if you find it.
Page generated in 0.15841 seconds with 5 queries
