02-07-2011, 09:59 | #1 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Afrique du sud Age: 42
Member: 430612 Status: Offline Thanks Meter: 301 | mobitel E71s FORMATTING OK BUT STILL DEAD module v3.26 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:9203:0004 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #02 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #03 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent ==================== New firmware found (v.3.26, database date: 13.01.2011): CK.MOBITELE71S.E17.F1.TVF.1.0.T01D091102.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 05 sw version: CK.MOBITELE71S.E17.F1.TVF.1.0.T01D091102.BIN project-id: CK.MOBITELE71S.E17.F1.TVF.1.0.T01D091102, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (05) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: CK.MOBITELE71S.E17.F1.TVF.1.0.T01D091102__ffs... file saved: C:\Program Files (x86)\InfinityBox\ChineseMiracle\CK.MOBITELE71S.E1 7.F1.TVF.1.0.T01D091102__ffs_20110207-085227.B0E.bin flash: EC240200000000:2AEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC240200000000:2AEA0000000000 Finalization Done Finished, time used: 7 min 53 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
02-07-2011, 21:39 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,536 | hello! make backup and flash it with some similar flash file starting with "CK." |
02-09-2011, 10:59 | #7 (permalink) |
Member: 430612 Status: Offline Thanks Meter: 301 | search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: CKT26_06B_PCB01_GPRS_MT6226_S01.SWAN+_6226_HL_L7SM _230_071101_LD0_0V0_SA75_CTF_BT__ffs... file saved: C:\Program Files (x86)\InfinityBox\ChineseMiracle\CKT26_06B_PCB01_G PRS_MT6226_S01.SWAN+_6226_HL_L7SM_230_071101_LD0_0 V0_SA75_CTF_BT__ffs_20110209-112727.B0E.bin flash: EC240200000000:2CEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Code CRC check error fix... firmware do not have "Code CRC check error" area Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... done detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: EC240200000000:2CEA0000000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 28 min 40 sec Remove/Install battery now ! i flash it but same problem |
02-10-2011, 07:39 | #10 (permalink) |
Member: 430612 Status: Offline Thanks Meter: 301 | COM9 [VCP0] selected module v3.26 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware CK.E71S.E17.F1.TVF.1.0.T03D090929_16m_En_Fr_Es_Id_ Tr_Farsi_Pt_Ar.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:9203:0004 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #02 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #03 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: CKT25_GEMINI_PCB01_GPRS_MT6225_S00.A522-5320_8G-2_109_080728.BIN project-id: A522-5320_8G-2_109_080728, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC240200000000:18E59F00000000 checking area [00000000]: 00080000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: CKT25_GEMINI_PCB01_GPRS_MT6225_S00.A522-5320_8G-2_109_080728__ffs... file saved: C:\Program Files (x86)\InfinityBox\ChineseMiracle\CKT25_GEMINI_PCB0 1_GPRS_MT6225_S00.A522-5320_8G-2_109_080728__ffs_20110210-083501.B0E.bin flash: EC240200000000:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Code CRC check error fix... firmware do not have "Code CRC check error" area Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... done detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: EC240200000000:18E59F00000000 Write: Firmware error: no any expected answer error: flash write error: 00000000:00002000 error: write operation failed Write Fail Finished, time used: 5 min 31 sec Remove/Install battery now ! same problem phone still dead |
02-10-2011, 20:51 | #11 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,536 | hello! this time writing failed: Write: Firmware error: no any expected answer error: flash write error: 00000000:00002000 error: write operation failed Write Fail you must search for reason |
FBUS works but MBUS not! PLS Help! | Upo | Nokia Hardware & Hardware Repair | 5 | 09-12-2000 14:54 |
6110 unlocked but wont give reception | KingOfKingston | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 04-10-2000 22:15 |
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) | tcamilo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-19-1999 22:30 |
Still with nokia 5110 ver 5.24 | VirtualM | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 11-11-1999 18:57 |
DOES THE CELLNET DIGA HACK STILL WORK??? | SP UNLOCKER 2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-04-1999 13:55 |
