I need help , plz infinity team c my proplem Hello I have this flash file E880_KDI1DOVF10_MT6225S00.GM_01_0_20080820(F10+宇顺8 347LCM+双OV7670)测试版本.IMG this file comming from china factory . coz i have 150 pcs needed to be arabic and my proplem is about *.IMG format how can i flash it with infinity ? Here is flash file http://rapidshare.com/files/15242769...79___3579.html Br |
If you have 150 pcs of same phone, why you donīt find pinouts, read flash backup, edit LP from you backup file saved than restore backup back from phone? Also, if all phones have same FW version you can write same backup in all pcs. B.r. Cryspim |
Thx |
after flash phone is daed and i do repair security area and still dead and it's orignal flash file [E880_KDI1DOVF4_MT6225S00.GM_01_0_20080804.BIN]_20080930-235348.B0M] Im waiting ur answer BR |
hello! i guess you must find exactly same "E880_KDI1DOVF4_MT6225S00.GM_01_0_20080804" firmware version. that one which i converted for you is slightly different |
1 Attachment(s) Quote:
hi.. i have these flah files.. especially the two flash maybe u need... pls check and tell me |
I donīt think these files will help you. Take a look: - You phone SW version: E880_KDI1DOVF4_MT6225S00.GM_01_0_20080804 - Used SW version: E880_KDI1DOVF10_MT6225S00.GM_01_0_20080820 I had big troubles once a time using a different file version (no matter if itīs just one letter only). Again: if you need to translate/modify a LP, AWAYS make a backup first. Better is edit your own backup file. Sometimes, identical phones have different SW versions inside. Now, take a look in one of you 150 pieces and try to find exactly SW to solve your problem. Itīs the only way. B.r. Cryspim |
but can read sim a & b i'm flashed with orignal falsh all ok but no arabic :( |
any help Infinity Team i'm Have same problem |
solution is following: first make full backup, second try Format FFS safe, complete. if did not help: make flashing by exactly same firmware version file. |
