Old 12-25-2009, 10:29   #1 (permalink)
Member: 430612
Thanks Meter: 301
i need picture how to solder wire to PCB
how to disassemble phone and solder wires directly to PCB
plz i need picture and how to connect to the box plz mate many phone with d500 pin charger dont find pinout
Old 12-25-2009, 15:56   #2 (permalink)
javeed_mp's Avatar
Member: 1166187
Sonork: 100.1616368
Thanks Meter: 168
open mobile any see test points on pcb RX TX and GND if not u have to measure it using multimeter on charging jack RX-2.8v and TX-2.7v
Old 12-25-2009, 17:28   #3 (permalink)
Member: 430612
Thanks Meter: 301
thankx but after finding tx and rx on board i can connect any cable or must i use pinfinder box for pinout again
Old 12-25-2009, 18:02   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
you can use direct cable.
here is example:
http://forum.gsmhosting.com/vbb/showthread.php?t=386780
Old 01-08-2010, 09:53   #5 (permalink)
Member: 430612
Thanks Meter: 301
thanx for picture i like this box but i need to learn more about this
what if i was givin the pinout like tx5 rx6 how to make this cable cause i dont know which coulor is tx or rx on cable connector?
Old 01-08-2010, 12:10   #6 (permalink)
Nabil3H's Avatar
Member: 17675
Thanks Meter: 18
if you have this cable
red --------> TX
white-------> RX
black--------> GND
The Following User Says Thank You to Nabil3H For This Useful Post:
Old 01-08-2010, 15:24   #7 (permalink)
Member: 430612
Thanks Meter: 301
mate i have infinity cable GF-AT106 J-TAG
and it has some pin which you can be able to connect to the phone
it has 2 gnd and rx,tx ,vpp can this cable work on this methode or wich cable can i use for this mate?
Old 01-09-2010, 20:36   #8 (permalink)
Member: 148515
hello!
i think you can use that cable. just find out which pins are tx,rx,gnd
Old 02-04-2010, 05:38   #9 (permalink)
Member: 430612
Thanks Meter: 301
i am confused this cable has 5 pin RX,TX,VPP,GND,GND there is 2 pin for gnd
so i try to connect tx,rx,gnd on pcb now where to connect vpp an other gnd
can i connect them to the bat pin or must i use power and leave this pin.plz i need help
because some of china phone came with d500 pin charger and we can not find pinout
Old 02-04-2010, 19:44   #10 (permalink)
Member: 148515
hello!
do not use Vpp, instead of it source phone from its own battery.
use any of GND (just one is enough) and tx&rx pins
Old 02-05-2010, 05:26   #11 (permalink)
Member: 430612
Thanks Meter: 301
let me try i will let you know sir
I need good solder wire ..::AppleLinks::.. Hardware Repair Item Wanted 8 11-10-2009 10:34
to solder or to not solder coolmax Motorola P2k 2 08-14-2006 11:29
how solder wire to mobile ghulab_khan32 SAGEM JTAG UNLOCKER 2 12-07-2005 02:49
how solder wire to mobile ghulab_khan32 SAGEM JTAG UNLOCKER 2 12-06-2005 22:11
Page generated in 0.20959 seconds with 10 queries
