11-24-2007, 09:22 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Due to a lot of different models with the same name but absolutely different hardware, bottom connectors and different pinouts we recommend you to include the next info: 1. detailed description of model 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ if not helps, please read: http:///vbb/showpo...36&postcount=7 if not helps, please read: http:///vbb/showthread.php?t=433447 |
11-24-2007, 17:19 | #5 (permalink) |
11-30-2007, 09:54 | #6 (permalink) |
Freak Poster Join Date: Feb 2006 Location: India
Member: 237210 Status: Offline Thanks Meter: 90 | hi infinity please look at this COM1 selected Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6228:8A02:8A02]... chip: 0031:0000:0101 Connecting, wait... error: can't finalize test moide Operation failed ! Finished, time used: 109 sec Remove/Install battery now ! phone is ZTC N38, restart problem is this pinout problem or anything else, please advice |
11-30-2007, 14:38 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello bhuvanele! if you hold power button pressed all the time while phone is booting- but still get error then this must be wrong pinout. where did you get pinout? |
11-30-2007, 18:38 | #8 (permalink) | |
Member: 237210 Status: Offline Thanks Meter: 90 | ztc n38 Quote:
i tried as said in pinout find instruction, but i think i only got tx pin right, any other ways to know rx pin, plz suggest | |
DAXIAN x999+ 10 pins need pin-out | mak_14344 | Infinity-Box | 3 | 07-15-2009 22:10 |
need help cect _t688+ ...cect_i658. need pin outs | arfantanveer | Infinity-Box | 9 | 12-04-2007 00:34 |
need pin-outs for processor GEMINI 1F35 | 205T | GSM Programming & Reverse Engineering | 2 | 08-03-2002 19:23 |
Need pin-out for C45 | -=GSM2002=- | x1x to x45/x50 | 3 | 04-05-2002 11:21 |
I need pin out for Siemens C30 | Spalato | NON Siemens Brand (ODM Phones) | 0 | 12-19-2000 12:56 |
