02-03-2010, 21:51 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! lets start from checking what CPU it is based. you either can do this by disassembling phone or by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software If it does supported, and you dont have infinity Pinfinder- i can teach how to find pinout in minutes. Just by measuring voltage on phone system connector pins. |
02-05-2010, 20:01 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! 1. set multimeter to voltage measuring. 2. power Onphone 3. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 4. with second probe touch one by one all phone pins (phone must be powered On) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. those are tx/rx |
need pinout GFIVE dual sim | mehrdad20072 | Chinese Models & Cloned Phones | 4 | 09-20-2009 18:30 |
Need TREND T500 DUal SIm pinouts urgent | mass_zoro | Chinese Models & Cloned Phones | 3 | 05-03-2009 16:54 |
Need pinout b889 dual sim | tsm2318 | Chinese Models & Cloned Phones | 2 | 03-02-2009 00:37 |
n81 dual sim flashfile help | fixed | PadFinder box | 12 | 12-14-2008 06:41 |
