09-02-2008, 12:19 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | i need pinout for sooy ersson k630i dual sim any solution pleease |
09-03-2008, 19:03 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @geti What was the reason to ignoremessage of respected Mr. Shakeel_pattoki ? what is connector type? what is cpu type? paste here photo of mobile. |
09-04-2008, 08:14 | #5 (permalink) |
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | conector is 20pin [VERSION] E890_YP10VFR11.01.0 [BRANCH]:GEMINI BUILD:BUILD_NO SERIAL#e89003090000756 CPU TYPE I DON`T KNOW |
09-07-2008, 10:39 | #12 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! here is fast and easy method to find pinout by yourself, if you dont have pinfinder: 0. Check battery voltage, it should be equal or more than 3,7 volts 1. set multimeter to voltage measuring. 2. set one multimeter probe to sone grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 3. with second probe touch one by one all phone pins (phone battery attached) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. those are tx/rx |
Speaker for YEPO K630i Dual SIM Card Phone | IPMART | ipmart WebShop | 0 | 07-15-2009 10:50 |
Fullset Housing for YEPO K630i Dual SIM Card Phone (red/black) | IPMART | ipmart WebShop | 0 | 07-15-2009 10:50 |
Camera for YEPO K630i Dual SIM Card Phone | IPMART | ipmart WebShop | 0 | 07-15-2009 10:50 |
Vibrator for YEPO K630i Dual SIM Card Phone | IPMART | ipmart WebShop | 0 | 07-15-2009 10:50 |
i need flash for chinese samsunc u900 dual sim | boumourad | Infinity-Box | 5 | 06-13-2009 23:24 |
