Old 11-24-2016, 03:47   #1 (permalink)
Yusuf Lawal's Avatar
Member: 1677653
Thanks Meter: 1,877
I need solution to itel it1409
Dear Infinity Team & fellow Users, i try to connect Itel it1409 to CM2 but not showing the sign of connection @all and my driver is properly installed.
please is anyone come across this before?
or is there a personal driver for this phone?
please let me hear from u........
Old 11-25-2016, 18:53   #2 (permalink)
Member: 2601900
Thanks Meter: 446
no special connection issue, just check the charging base and the USB it accept is that one with short head
The Following User Says Thank You to mmtheo For This Useful Post:
Old 11-25-2016, 19:31   #3 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,338
what cpu inside?
If Spd download drivers v1.01 from Support
hope to be Android 5.0
The Following User Says Thank You to Kirumira For This Useful Post:
Old 11-25-2016, 21:19   #4 (permalink)
Member: 1677653
Thanks Meter: 1,877
Originally Posted by Kirumira View Post
what cpu inside?
I cannot even know the CPU type because system doesn't see phone @all.
Old 11-26-2016, 07:03   #5 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,338
Hello
what is your phone state?
Try open Device manager,hold boot key,connect phone
what do you see?
Old 11-28-2016, 19:37   #6 (permalink)
Member: 2601900
Thanks Meter: 446
itel 1409 is 7731g modem.if your drivers are installed correctly, it should detect,
Old 11-28-2016, 19:42   #7 (permalink)
Member: 2457240
Sonork: 100.1662388
Thanks Meter: 74
Pm me for solution
Sent from my iPhone using Tapatalk
The Following User Says Thank You to ramanmobile For This Useful Post:
Old 11-28-2016, 22:32   #8 (permalink)
Member: 1677653
Thanks Meter: 1,877
Can u please share direct link for the driver?
Old 11-28-2016, 23:36   #9 (permalink)
gunit1's Avatar
Member: 2041210
Thanks Meter: 489
u need press volume down & connect usb cable it's will in boot mode
Old 11-28-2016, 23:42   #10 (permalink)
Member: 1677653
Thanks Meter: 1,877
i have try this but not work.....
Old 11-28-2016, 23:47   #11 (permalink)
gunit1's Avatar
Member: 2041210
Thanks Meter: 489
what's exactatly problème the phone
when u press down & insert cable it show in peripheri gestion ?
Old 11-28-2016, 23:53   #12 (permalink)
Member: 1677653
Thanks Meter: 1,877
answer 1:-phone problem is frp lock
answer 2:-phone brick and off back try more than 20times but the same...
Old 11-29-2016, 00:07   #13 (permalink)
gunit1's Avatar
Member: 2041210
Thanks Meter: 489
flash with that frmwr
https://docs.google.com/uc?id=0B4iGb...xport=download
solution frp
How to remove FRP Lock /Google Account Protection on spreadtrum devices like itel,opsson, etc with 2016 security patch - DSMEDIA24
all other help contact me
https://www.facebook.com/moussamohamed.gbane
Old 11-29-2016, 00:15   #14 (permalink)
Member: 1677653
Thanks Meter: 1,877
boss, u're great.
more Greece to ur elbow.....
The Following User Says Thank You to Yusuf Lawal For This Useful Post:
Old 12-14-2016, 10:00   #15 (permalink)
Member: 1144926
Sonork: 100.1646998
Thanks Meter: 2
boss, u're great.
file is no longer valid. please give another link
Page generated in 0.38257 seconds with 7 queries
