Old 11-20-2018, 19:46   #1 (permalink)
Member: 1677653
Thanks Meter: 2,769
I need solution for tecno ca6 dead boot
DEAR FELLOW USERS, KINDLY HELP ME FOR THE SOLUTION TO THIS DEAD TECNO CA6.
THANKS IN ADVANCE.
Operation : Identify [ v2.02 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM14)
MODE : BOOTROM
PORT : 14
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCC00 , SWVR : 0x0000
TYPE : LEGACY MTK
BROM : SecLevel : 0x00000005
BROM : SecMode : SBC+SDA
BROM : BOOTROM
MODE : 0_base : BASE_v1836 | Manual : Enabled
Fail to disable Dog!
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6735
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : 0x00007017 : DA SEND ERROR!
ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE!
INFO : BROM Level : CERT/AUTH required! Try boot device in PRELOADER mode with select PL/PL_CRYPTO type!
Error : Fail to init protocol!
Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
Reconnect Power/Cable!
Old 11-20-2018, 19:50   #2 (permalink)
SkyCleaner's Avatar
Member: 2697846
Thanks Meter: 77
If only I had a stable & reliable connection for uploading files I would have uploaded it for you. But don’t give up, the solution there is to write it’s factory signed firmware with tecno aftersales tool.
Goodluck
Sent from my iPhone using Tapatalk Pro
The Following User Says Thank You to SkyCleaner For This Useful Post:
Old 11-20-2018, 19:52   #3 (permalink)
Member: 1677653
Thanks Meter: 2,769
I would be very grateful if you can upload for me.
Thanks in advance
Old 11-20-2018, 19:59   #4 (permalink)
SkyCleaner's Avatar
Member: 2697846
Thanks Meter: 77
Thanks in advance
Well there’s one on support, have u tried it?? Uploaded since April.
Goodluck
Old 11-20-2018, 20:03   #5 (permalink)
Member: 1677653
Thanks Meter: 2,769
Goodluck
not yet brother.
although i had one signed/factory firmware that i been use to fix many Tecno CA6 but due to dead boot of this particular one the file unable to fix it...
Old 11-20-2018, 20:06   #6 (permalink)
SkyCleaner's Avatar
Member: 2697846
Thanks Meter: 77
not yet brother.
Thought you had none. Tried through SWD_AfterSAles.exe too?
Old 11-20-2018, 20:38   #7 (permalink)
Member: 1677653
Thanks Meter: 2,769
yes brother.
but the tool refused to work on my both pc....
Old 11-20-2018, 20:46   #8 (permalink)
SkyCleaner's Avatar
Member: 2697846
Thanks Meter: 77
yes brother.
http://www.mediafire.com/file/and3d0...htool.rar/file
Try to run this one
The Following 2 Users Say Thank You to SkyCleaner For This Useful Post:
Old 11-20-2018, 21:35   #9 (permalink)
Member: 1677653
Thanks Meter: 2,769
Tecno Flashtool
Try to run this one
Alright,
I will try it tomorrow.
Old 11-20-2018, 22:54   #10 (permalink)
Member: 2812901
Thanks Meter: 493
pls upload the file for benefit others
Sent from my TECNO G9 using Tapatalk
Old 11-21-2018, 08:02   #11 (permalink)
Member: 1535920
Thanks Meter: 31
I am also having tecno ca6 dead and giving same error while trying to flash it. I have tried two signed firmwares and not solved. If anyone has solved this problem he should please share his solution. Thanks
Old 11-21-2018, 10:29   #12 (permalink)
Member: 1677653
Thanks Meter: 2,769
nobody will give u signed firmware for free unless u will try the one on infinity download area
Page generated in 0.22733 seconds with 9 queries
