03-27-2018, 17:37 | #1 (permalink) |
No Life Poster Join Date: Sep 2011 Location: Dhaka,Bangldesh
Member: 1659078 Status: Offline Sonork: Mahidi Munna Thanks Meter: 199 | I need tecno in5 nvram file 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 174 ] Sync... Init Ok, waiting for phone ... Reading initial info, wait... Phone Info : BB : AT+EGMR=0,0 HW : AT+EGMR=0,4 SW : AT+EGMR=0,3 MM : AT+EGMR=0,1 VR : AT+EGMR=0,2 SN : AT+EGMR=0,5 Security Info : IMEI [1] : AT+EGMR=0,7 IMEI [2] : AT+EGMR=0,10 IMEI [3] : AT+EGMR=0,11 IMEI [4] : AT+EGMR=0,12 Read Ok! Update IMEI[1] to : 355788065655137 failed , record not exist or NVRAM damaged! Update IMEI[2] to : 355788065655129 failed , record not exist or NVRAM damaged! Done! Elapsed: 00:01:17 Reconnect Power/Cable! ANY BODY HELP ME TO FIX IT..MY DEVICE IS NOW NO SERVICE MODE.. |
03-28-2018, 06:04 | #3 (permalink) | |
Member: 1659078 Status: Offline Sonork: Mahidi Munna Thanks Meter: 199 | Bro..Permanent Mode Fail Quote:
Chinese Miracle II [MTK module] v 1.58 Operation : Repair Security [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 174 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:19 Reconnect Power/Cable! | |
04-02-2018, 20:34 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,925 | This type of security boot option is not supported yet in automatic mode, work is in progress. You can try to search forum to get result with other DA files. |
