10-23-2009, 21:57 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Albania,City Under The Castle Age: 47
Member: 388033 Status: Offline Thanks Meter: 693 | I need urgent |
10-24-2009, 19:34 | #2 (permalink) | |
Could you, please, post here what is your phone connector type, how many pins. Also, please, post here first 4 (only first 4) digits of your Infinity-Box S/N so we can check that you are really Infinity-Box user. Thank you very much for your kind information about your phone and for your verification that you are really Infinity-Box user. | |
10-24-2009, 19:50 | #3 (permalink) |
No Life Poster Join Date: Sep 2007 Location: MUMBAI
Member: 583454 Status: Offline Thanks Meter: 80 | Sir i also want test points for niktel A950 , my infinity serial number starts with 8749 ... It has charging/connectivity socket of 24pin (like samsungR220) |
10-26-2009, 16:02 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! guys, if you sure that your phone is MT62xx MCU- i can teach how to find pinout using multimeter. after that you can solder own cable. tip: you can check this by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is MT62xx family |
10-27-2009, 21:53 | #5 (permalink) |
Member: 388033 Status: Offline Thanks Meter: 693 | here are the serial numbers of my box and the phone Loading data, wait... S/N: zxzx:0112 Wait... Device: Autodetect 6205-6227 NOR Done MODEL E555 GSM 850/900/1800/1900 M-IMEI 354092030142185 S-IMEI 354092030142193 Last edited by InfinityHelp; 10-28-2009 at 00:31. |
10-28-2009, 00:33 | #6 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
absolutely not necessary to post your dongle number here. lets start from checking what CPU it is based. you either can do this by disassembling phone or by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software If it does supported, and you dont have infinity Pinfinder- i can teach how to find pinout in minutes. Just by measuring voltage on phone system connector pins. | |
02-26-2010, 17:15 | #9 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Albania
Member: 137489 Status: Offline Thanks Meter: 68 | Pinout is under battery,you have 5 point the first is tx then rx and you have 2gnd,hope you solve the problem .. |
The Following User Says Thank You to Gerti For This Useful Post: |
need urgent v400 motorola need flash file | darmiles | Motorola P2k | 2 | 09-19-2007 04:33 |
need 2280 reliance ufsx flash file need urgent | vinay_sharma | Nokia CDMA | 3 | 08-24-2007 07:18 |
S500i I need CENTRAL EUROPE lang pack can you upload I need urgent !! !! !! | wgmmmx | MT-BOX | 21 | 08-16-2007 15:00 |
CF61 dead I need fullflash if someone have pleasse upload I need urgent | wgmmmx | VygisToolbox | 2 | 02-04-2007 23:45 |
URGENT,need urgent BG unlock SW!!! | evilspell | Wanted Products | 7 | 02-14-2003 16:41 |
