12-15-2007, 07:35 | #1 (permalink) |
Freak Poster Join Date: Feb 2007 Location: india / gujarat Age: 37
Member: 447024 Status: Offline Sonork: 100.1609935 Thanks Meter: 23 | i needded pinout cect s500 pinout Any body knows pinout for CECT S500 it has 12pin data port. plaese give this handset rx tx grund picture plzplzpzl please help me any budy |
01-19-2008, 13:56 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! this is VERY RARE hardware configuration of S500 CECT. there is no pinout information in our oinout collection as well as nothing if you search on support forum. i would advice following: 1. measure voltage on all pins (phone powered On, will not work on restarting phones) and then reffer to this method: http:///vbb/attach...7&d=1187384324 2. use brutoforce method: try all possible combination of tx/rx to boot phone with 2x6 pins this will give 132 combinations 2. wait some of our forum member to help you. in this case i would advice to update your phone data with position of GND and charging pins. 3. Wait our automaticly finding pinout box to be released hopefuly we will annonce it before chinese new year |
01-21-2008, 23:39 | #5 (permalink) |
Freak Poster Join Date: Dec 2004 Location: algeria Age: 48
Member: 95613 Status: Offline Thanks Meter: 17 | dire infinty team for cecet s500 conecteur 1x18 idont finder rx tx i use vprom box from frend i use auto finder pinout end not secsese i find only gndin pin 12 15 16 end 10 is vcc...then perhaps tx end rx are in the phone i will open the phone end i si in it if i fider the just pinout i will post rusilta for all meber kip working |
05-04-2008, 09:38 | #6 (permalink) | |
Freak Poster Join Date: Apr 2008 Location: Australia
Member: 740993 Status: Offline Thanks Meter: 75 | Quote:
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: SZMI25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_24.B IN ver. sw2: MAUI.06B.W07.24, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: EC257E25082501:18E59F00000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: EC257E25082501:18E59F00000000 Finalization Done Finished, time used: 158 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! thanks smartengg | |
i-phone cect s500 format ok with pinout | keaelite | Infinity-Box | 1 | 08-08-2008 11:25 |
need this cect n88 pinout please | Tinotenda | Infinity-Box | 5 | 06-26-2008 10:32 |
i need china cect s168 pinouts. | sahil00150 | Chinese Models & Cloned Phones | 0 | 05-08-2008 17:54 |
need new cect Q500 pinouts | bassam_gsm | Infinity-Box | 6 | 03-21-2008 16:02 |
Need Chines Cect 808 Pinout | DYNET | Chinese Cocktail | 2 | 02-11-2008 08:55 |
