02-20-2017, 19:35 | #1 (permalink) |
No Life Poster Join Date: Jan 2014 Location: africa mali
Member: 2098907 Status: Offline Thanks Meter: 154 | I think cm2 not supported new mtk with security boot 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:05 Reconnect Power/Cable! |
02-20-2017, 19:35 | #2 (permalink) |
Member: 2098907 Status: Offline Thanks Meter: 154 | Mtk6737 with securityboot is supported ? CM2 INFOS Phone found! [ 24 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! |
02-21-2017, 12:02 | #3 (permalink) |
Junior Member Join Date: Feb 2013
Member: 1878321 Status: Offline Thanks Meter: 0 | Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 18 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:05 Reconnect Power/Cable! |
02-25-2017, 06:14 | #7 (permalink) |
Freak Poster Join Date: Mar 2008 Location: India
Member: 718338 Status: Offline Sonork: 100.1623688 Thanks Meter: 43 | pls make a bootloader unlock tab in fastboot v......no provide why infinity can not some time success by cmd but it is big headach to user pls ad bootloader unlock for loyal user |
02-25-2017, 06:31 | #8 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | BL unlock over fastboot will chasnge NOTHING. Don't follow stupid lolcano advertizes next time. |
02-25-2017, 06:39 | #9 (permalink) |
Freak Poster Join Date: Jan 2007 Location: India.Pin.629001
Member: 433257 Status: Offline Thanks Meter: 43 | So is there any other options (anything you suggest ) Hoping for you guys to crack open something like you did on qlm phones . Just a request and hoping for the best . |
The Following User Says Thank You to maximas007 For This Useful Post: |
02-25-2017, 07:04 | #10 (permalink) |
Member: 718338 Status: Offline Sonork: 100.1623688 Thanks Meter: 43 | i have cm2 user but i tried one month free that box i sucess with 2-3 phone i request 4 bootloader unlock or buy that activation respect u r user sir and it s suggetion from infinity user of nearly ten year cdma tool best tool dcunlocer also why r u r...e |
02-27-2017, 08:19 | #11 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Work is in progress, step-by-step new features comes - https://www.infinity-box.com/news.php |
The Following 3 Users Say Thank You to InfinityHelp For This Useful Post: |
01-06-2018, 12:16 | #13 (permalink) |
Junior Member Join Date: Feb 2017
Member: 2680251 Status: Offline Thanks Meter: 0 | Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:04 Reconnect Power/Cable! |
