Old 05-17-2008, 11:44   #1 (permalink)
Member: 609370
Thanks Meter: 13
i think this n95 is new version-did format ffs-set dead
this is the second time n95 (v3type jack) rx,tx in board reboot problem-did format ffs-after it set dead.
my first case same problem in below link.
https://forum.gsmhosting.com/vbb/f296/nokia-n95-reboot-did-format-ffs-after-set-dead-help-537523/
the detailed info and format ffs details as below
COM6 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: read/check detailed information
Boot...
19200 fixed
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:1136:83A6
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: 01227E22202200:29EA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.AE8ACC1A.[T6226_05C_PCB01_GPRS_MT6226_S01.B10_EFATRIS_V1217A .BIN_103A0BEB].rpl
identification#1 detection finished
device-id: AE8ACC1A
identification#1 protocol ver: 04
ver. sw1: T6226_05C_PCB01_GPRS_MT6226_S01.B10_EFATRIS_V1217A .BIN
ver. sw2: B10_EFATRIS_V1217A, 14F4C5EF
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
detecting ffs structure pass 1...
detect standard fat location pass #1...
detect extended fat location pass #1...
detect standard fat offset pass #1...
detect standard fat data...
fat layout detection complete
ffs element #1 detected ok
detecting ffs structure pass 2...
ffs element #2 detected ok
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _AE8ACC1A_T6226_05C_PCB01_GPRS_MT6226_S01.B10_EFAT RIS_V1217A.BIN_103A0BEB_20080517-134715.B0X.bin
Finished, time used: 171 sec
Remove/Install battery now !
format ffs
Action: reset settings
Model: Autodetect 6205-6227 NOR
19200 autodetect
CPU: MT6226
Connecting, wait...
Phone detected, wait...
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: B10_EFATRIS_V1217A
Version:
detecting structure #2...
done
60 byte(s) read
imei: 35783501064644
connection Ok
building list...
done
items to clear: 184
warning: wrong packet cs
182 of 184 items cleared
building list...
done
0 items remains
Finished, time used: 56 sec
NOW I THINK THIS MODEL IS NEW SOFTWARE VERSION-SO WHAT I DO TO TURN ON ABOVE SETS?
help me
thank u
Old 05-17-2008, 11:46   #2 (permalink)
ABOUSHADY's Avatar
Member: 200717
Sonork: 100.1580056
Thanks Meter: 793
restor eeprom and reformat again
Old 05-17-2008, 12:41   #3 (permalink)
mohamed75's Avatar
Member: 102762
Sonork: 1583079
Thanks Meter: 186
you have been warned many many times to backup full flash from those buggy phones b4 doing anything and i donot know why u cry now
Old 05-17-2008, 12:54   #4 (permalink)
Member: 609370
Thanks Meter: 13
for the second phone i have backup
backup_flashT6226_05C_PCB01_GPRS_MT6226_S01.B10_EF ATRIS_V1217A.BIN]_20080517-141922.B0M(16mb)
restored-set again now reboot.
my problem is it due to now infinity not support this version?
Old 05-17-2008, 13:54   #5 (permalink)
mohamed75's Avatar
Member: 102762
Sonork: 1583079
Thanks Meter: 186
did u try safe format method?
Old 05-17-2008, 14:04   #6 (permalink)
Member: 609370
Thanks Meter: 13
yes-after it set dead.
Old 05-17-2008, 18:17   #7 (permalink)
Member: 609370
Thanks Meter: 13
have any friends have suceesfully format n95 china rx,tx on board type set?
if yes help me
thank u
Old 05-17-2008, 18:57   #8 (permalink)
Member: 609370
Thanks Meter: 13
tried in latest version chineese miraclev2.43 also.but did not sucess-after ffs set dead.
19200 autodetect
CPU: MT6226
chip: 0031:7B2A:AAE4
Connecting, wait...
Date: 2005.04.12
Version: 1.0
Version:
done
60 byte(s) read
connection Ok
building list...
done
items to clear: 184
building list...
done
0 items remains
Finished, time used: 47 sec
so i think this type has some problems in infinity
Old 05-17-2008, 20:06   #9 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
what result gives complete format?
please upload full backup from restarting set to www.rapidshare.com
Old 05-18-2008, 04:42   #10 (permalink)
Crazy Poster
Member: 44820
Thanks Meter: 2
yup same with me try format ffs safe mode but phone not power on...
full flash with file in support area phone alive again...
but
try to format again after full flash phone dead again even i try repair security area....
my fault dont have full backup...
but flash with file in support area phone is ok
Old 05-18-2008, 05:43   #11 (permalink)
Member: 609370
Thanks Meter: 13
but
have u the eeprom area backup?
Old 05-18-2008, 07:57   #12 (permalink)
Crazy Poster
Member: 44820
Thanks Meter: 2
no bro...
but phone is ok if i dont format ffs....
Old 05-18-2008, 08:45   #13 (permalink)
TURNING POINT's Avatar
Member: 71721
Sonork: 100.106320
Thanks Meter: 139
no bro...
you format in safe mode and phone getting dead???
i never face this problem
but after format you need to press power on switch approx 1 min and some time repit this process 2/3 times
or u may try last option"FFS" this option is al so safe
but for full format you need to check "backup system area" then auto backup will be created
Old 05-18-2008, 11:57   #14 (permalink)
Member: 148515
hello!
for me it is also very strange, that phone dies after safe format.
here is little hint: while you making safe format you can include or exclude different Iteams.
by enabling small parts on after another (and each time making format) you can find iteam which kills phone.
then exclude it from format - and you should get success format
Old 05-18-2008, 12:23   #15 (permalink)
Crazy Poster
Member: 44820
Thanks Meter: 2
yup for me it is also very strange because usually for restart problem i just do format ffs in safe mode not full...
i try it every finish full flash... but phone always dead....
may be eeprom the phone is damage....?
n95 reboot-did format ffs-still in reboot-can i flash? zonetrichur Infinity-Box 16 06-30-2008 14:25
N95 V3 Type Jack Dead-did Format Ffs-still In Dead zonetrichur Multi-Box 4 05-15-2008 13:24
nokia n95 reboot-did format ffs-after it set dead-help zone2 Infinity-Box 1 05-14-2008 14:49
After format ffs kg300 dead Y2ksalman Infinity-Box 3 10-04-2007 16:21
I think this forum is dead! Jaca Off Topic Zone 0 07-25-2001 01:39
Page generated in 0.28831 seconds with 9 queries
