09-07-2008, 08:14 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Georgia GE
Member: 162473 Status: Offline Sonork: Not have Thanks Meter: 592 | I try unlock TECNO Mp3 Player but no result ;( COM6 [VCP1] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "sp-unlock" unlock method: standard fast Unlock procedure can be faster if you skip eeprom area backup procedure. Do you want to disable eeprom backup ? eeprom backup disabled Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E220A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #01 in region #00... flash: 01227E220A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #02 in region #00... flash: 01227E220A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #03 in region #00... flash: 01227E220A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #04 in region #00... flash: 01227E220A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #05 in region #00... flash: 01227E220A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #06 in region #00... flash: 01227E220A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #07 in region #00... flash: 01227E220A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb number of flash chip/regions detected: 08/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E220A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #01 in region #00... flash: 01227E220A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00400000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: M280A_PCB01_GSM_MT6205B_DN.L5A1K01_6_2_1_3T05S1212 _M401C.BIN ver. sw2: L5A1K01.6.2.1.3T05S1212_M401C, 00000000 ffs offset/size: 00380000/00080000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00380000 flash: 01227E220A2201:18E59F00000000 checking area[00000000]: 00000000-003FFFFF... eeprom/ffs found near: 00380000 detecting eeprom/ffs size... eeprom/ffs size: 00080000 ffs chip: 00 eeprom/ffs area: 00000000:00380000-003FFFFF detecting ffs structure pass 1... ....... detect standard fat location pass #1... detect standard fat offset pass #1... detect standard fat location pass #2... . detect standard fat offset pass #2... detect standard fat location pass #3... ........... detect standard fat offset pass #3... detect standard fat data... fat layout detection complete ffs element #1 detected ok Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: 01227E220A2201:18E59F00000000 Backup required data Done Patch required data... ............ lock area found Patch required data Done Special operation... Special operation Done Write... flash: 01227E220A2201:18E59F00000000 flash: 01227E220A2201:18E59F00000000 Write: lock-area-1 Write Done Finalization... Finalization Done Finished, time used: 34 sec Remove/Install battery now ! same result with all mode SP Unlock but no result ;( i try flash this phone with flash file downloaded from support area, but same ... software version: 1.14 cable type: 1x8 (L8A) platform: MT: MT6205, MT6217-MT6228, MT6230 searching adapter at COM6... adapter found, version: 2000 pins: 8, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT6205 result: Rx:3 Tx:4 time required: 9 sec Power On ! saved: TECNO_MP3_Player |
09-08-2008, 00:10 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | I can't believe that MP3 phone has only one PU with 4Mb flash chip. Please, open phone and check what is 1st and 2nd CPU. You need to unlock 1st CPU but not 2nd. If you are sure that this phone has 1 CPU only (but I don't think so) you must try to use different unlock methods, but my advice: open phone and check how many CPU is inside this phone. |
09-08-2008, 06:48 | #5 (permalink) | |
Member: 162473 Status: Offline Sonork: Not have Thanks Meter: 592 | Quote:
09-09-2008, 18:04 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, 1. read full flash and send it to [email protected] 2. include detailed problem description in your mail 3. incliude pinout in your mail. We will check backup file and think what can be done in this situation. |
i m unlock 2 ps i phone3g3.1.2 unlock using black ran but no network | ravin j tejura | iPhone 2 / iPhone 3G / iPhone 3GS | 3 | 02-05-2010 16:12 |
write flash checksum but no result | aminnovelty | Universalbox | 3 | 08-09-2008 11:59 |
got an od t29s to unlock, cruiser boot it, but no unlock tab | ashvin | Cruiser Suite | 1 | 11-21-2005 10:18 |
