04-24-2008, 17:18 | #1 (permalink) |
Junior Member Join Date: Apr 2008
Member: 743742 Status: Offline Thanks Meter: 0 | i want know which part are detected. Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:035B:69ED Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: E550_A5FRENCHBT.01.1_26S01 Version: M500Z_05C_HW detecting structure #2... done 60 byte(s) read imei: 35410100022849 connection Ok building list... done items to clear: 200 181 of 200 items cleared building list... done 0 items remains Finished, time used: 122 sec Remove/Install battery now ! |
04-24-2008, 18:43 | #2 (permalink) |
Member: 743742 Status: Offline Thanks Meter: 0 | http:///vbb/showthread.php?t=529071 please give a proper replay bcz some post infinity supporters saying use reverse some one saying solder. confused. if pinfinder not detecting second mcu its bad news. |
04-24-2008, 19:49 | #3 (permalink) | |
Freak Poster Join Date: Sep 2007
Member: 583680 Status: Offline Thanks Meter: 47 | Quote:
In Your case You have detected CPU1,see Your log (MT6226). Before You start playing with phone-first make backup of fullflash.After You have done it-compare both backup_flash_*********xx.bom.bin files.Main CPU flash file usualy is 7-10 Mb,second CPU flash file is 1-3(max 4)Mb. Good luck! -------- ezzis | |
04-24-2008, 20:28 | #4 (permalink) | |
Member: 743742 Status: Offline Thanks Meter: 0 | Quote:
how to know which activations are active on my ub box | hafiz_anjum | Universalbox | 2 | 07-21-2009 09:51 |
(n70) i want to know which components are required for network with diagram | asif_ae | Nokia Hardware & Hardware Repair | 1 | 06-06-2009 16:19 |
Which parts are compatible? | Frogy DJ | Nokia Hardware & Hardware Repair | 3 | 09-01-2008 11:30 |
How To Know Which Languages Are Inside A Firmware ?? | tsarkh | BlackBerry (RIM) | 1 | 06-20-2008 09:16 |
how to know which languages are in flash files? | yakety | Nokia Base Band 5 ( BB-5 ) | 3 | 02-07-2008 12:19 |
