05-12-2016, 13:46 | #1 (permalink) |
No Life Poster Join Date: May 2014
Member: 2195211 Status: Offline Thanks Meter: 4,294,967,295 | I2 connecting problem Android version: 5.1 Baseband: TM_BASE_MP_II_W15.42|sc7731g_CP0_modem|10-27-2015 15:14:45 >> The above information is for reference only. How to connect it? |
05-12-2016, 13:56 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, First select SP [SC7730..7731] eMMC [Android 5.x] under cpu selection. Try Alternative LDR mode or try to select SLDR file manually. If still not works need to select similar .pac file as base. Br. Infinity Box Support Team. |
05-12-2016, 15:12 | #5 (permalink) |
Member: 2195211 Status: Offline Thanks Meter: 4,294,967,295 | By selecting SLDR here is logo Operation : Check/Read Info [ v1.18 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 7 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC v2.0 Loader Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! Unknown structure detected! Check correct model selection! Elapsed: 00:00:29 Reconnect Power/Cable! |
05-12-2016, 15:31 | #6 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Also try with SC773x_eMMC_v3 sldr and other sldr files. If you have .pac file select it as base and try. Br. Infinity Box Support Team. |
05-12-2016, 15:58 | #7 (permalink) |
Member: 2195211 Status: Offline Thanks Meter: 4,294,967,295 | after selecting v3 file Operation : Check/Read Info [ v1.18 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 7 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC Loader v3.0 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! Unknown structure detected! Check correct model selection! Elapsed: 00:00:21 Reconnect Power/Cable! |
05-12-2016, 16:42 | #8 (permalink) |
No Life Poster Join Date: Sep 2015 Location: SINDH, PAKISTAN.
Member: 2452939 Status: Offline Thanks Meter: 256 | Just check '' format '' and let us know the result that ''format'' is working on this phone or still have any other error too. And post the log of ''format'' too. Just for the checking the result on this phone. |
