Old 03-07-2009, 22:09   #1 (permalink)
PILONCILLO's Avatar
Member: 26692
Thanks Meter: 51
i9 iphone cant writhe imei
i have some those phones.i can backup fw and any other work were phone is pwr of.the imei are changued to default and i need changue to the label but phone must be powred on and my pind finder cant.
pin 1 have 4.27 vots and infinity box too.i dont find any diode in my infinity for cut.(that manual is for very old boards only.my infinity is from unlockcellular and is rectangular short black box).
y try with fully chargued battery too and cant make job becouse never conect.
i had worked many others iphones like iphoe,p168 etc and all is ok.only in these model is the problem.
Old 03-08-2009, 01:06   #2 (permalink)
PILONCILLO's Avatar
Member: 26692
Thanks Meter: 51
i begin tryng to writhe imei
but now i use the test point cable of rocker box(zulea not legija tp cable)
for pwer the phone and sw tray to conect but was unsusefull.
butttttttttttttttttttt...... i use the same boxes:infinity in com 8 .next pinfinder and tp cable like power and using cracked other chinese box imei was writed in pone in a second.
so infinity you have problem for conect these models of iphones in pwer on mode.i have pics and logs
Old 03-08-2009, 22:59   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
4,27 is volatge which was cut by diode.
you just must find it where it is located.
after you remove it- pinfinder work will increase dramaticaly
Old 03-09-2009, 19:33   #4 (permalink)
PILONCILLO's Avatar
Member: 26692
Thanks Meter: 51
hello!
sorry i cant find any diode.you produce it not me ,then please post were is located.
if there are many versions of boxes you must have diagrams or pic each one i suposse.
Old 03-10-2009, 11:21   #5 (permalink)
Member: 148515
hello!
can you post your box PCB picture (components side)
it must be in good focus
i will try to suggest which diode must be shorted
Old 03-12-2009, 01:26   #6 (permalink)
PILONCILLO's Avatar
Member: 26692
Thanks Meter: 51
here you are,i hope be usefull
Old 03-12-2009, 01:46   #7 (permalink)
PILONCILLO's Avatar
Member: 26692
Thanks Meter: 51
my infinity box board pictures
Old 03-13-2009, 00:41   #8 (permalink)
Member: 148515
hello!
looks like it is VDD2 ?
Old 03-14-2009, 01:19   #9 (permalink)
PILONCILLO's Avatar
Member: 26692
Thanks Meter: 51
what do you mean?
here atached some pics of my boxes
first my infinity and next pin finder
Old 03-14-2009, 23:08   #10 (permalink)
Member: 148515
hello!
remove VDD2, set jumper
check if this increase output voltage from 4,2 to +5v
M7600 - Cant repair IMEI - Cant read Security data marquesphelder Z3X-Team Products 9 08-06-2010 07:14
2 pcs iPhone 2G No IMEI, No ICCID, Cant Make & Receice Calls dannyogolo iPhone 2 / iPhone 3G / iPhone 3GS 8 08-01-2009 20:05
iphone cant recive call on standby kasra iPhone 2 / iPhone 3G / iPhone 3GS 8 05-31-2008 19:30
iphone cant make call from keypad quantumgsm iPhone 2 / iPhone 3G / iPhone 3GS 0 11-29-2007 21:14
v70 cant unlock cant change imei click190 Motorola P2k 0 06-24-2003 09:50
Page generated in 0.20103 seconds with 11 queries
