11-12-2009, 19:46 | #1 (permalink) |
No Life Poster Join Date: Apr 2002 Location: The Green Mile
Member: 11325 Status: Offline Thanks Meter: 266 | i9 phone code got this iphone imitation and wish to remove the phone lock. tried the 1212 and the rest with no success. Cannot do master reset as i am gettign the lock as soon as it is started Any idea if this is supported by infinity pls? Should be but am quite lost on this one. thanks for any help |
11-12-2009, 19:56 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! first of all try code 1122 next make full backup and do format FFS complete |
11-12-2009, 21:49 | #4 (permalink) |
Member: 11325 Status: Offline Thanks Meter: 266 | Solved Mate! ...thanks! COM4 [VCP0] selected module v2.94 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:CA03:0000 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC227E22632260:18E59F00000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb detecting chip #01 in region #00... flash: EC227E22632260:18E59F00000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC227E22632260:18E59F00000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb detecting chip #01 in region #00... flash: EC227E22632260:18E59F00000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 02000000 searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info protocol ver: 04 ver. sw 1: XRY_PCB01_GPRS_MT6225_S00.A5188V1_0.BIN ver. sw 2: A5188V1.0, 00000000 address offset: 00000000 ffs offset/size: 01C00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 01C00000 flash: EC227E22632260:18E59F00000000 checking area [00000000]: 00000000-01FFFFFF... ffs/eeprom found near: 01C00000 detecting ffs/eeprom size... ffs/eeprom size: 00400000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:01C00000-01FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: XRY_PCB01_GPRS_MT6225_S00.A5188V1_0__ffs... file saved: D:\XRY_PCB01_GPRS_MT6225_S00.A5188V1_0__ffs_200911 12-213253.B0E.bin flash: EC227E22632260:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... ffs formatting... flash: EC227E22632260:18E59F00000000 Finalization Done Finished, time used: 229 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to Burnt Cobba For This Useful Post: |
Swedish language for I9 phone | loman76 | Chinese Models & Cloned Phones | 0 | 09-12-2008 01:16 |
i9 Phone Earphone | IPMART | ipmart WebShop | 0 | 09-10-2008 16:10 |
i9 Phone USB Data Cable | IPMART | ipmart WebShop | 0 | 09-10-2008 16:10 |
i9 Phone charger | IPMART | ipmart WebShop | 0 | 09-10-2008 16:10 |
i9 Phone Battery | IPMART | ipmart WebShop | 0 | 09-10-2008 16:10 |
