i9060 need flash file i had just wanted to remove security code but now phone stuck on samsung log,lease help. ;););) Chinese Miracle II [MTK module] v 1.10 Operation : Check / Read Info [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : M00U5 [eMMC] : FLASH_CID : 1501004E355530304D02BA994F4F301F [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read Ok! Done! Elapsed: 00:00:25 Reconnect Power/Cable! |
Hello, Do you know what is required firmware version ? |
Does it stuck at logo after format with CM2MTK? Format phone with FMT set to "0" in setting while format. If still stck at logo after format with "0" setting do Fix DL Mode. Br. |
