Old 02-02-2015, 17:52   #1 (permalink)
ibrajinja's Avatar
Member: 562975
Sonork: better tomorow
Thanks Meter: 247
i9060 need flash file
i had just wanted to remove security code but now phone stuck on samsung log,lease help.
Chinese Miracle II [MTK module] v 1.10
Operation : Check / Read Info [ v1.10 ]
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6575
BB_CPU_HW : CB00
BB_CPU_SW : 8A00
BB_CPU_SB : E201
BB_CPU_NM : [MediaTek] MT6575_S00
Processing BROM stage
i2c Init : 00000000
SpeedSet : 0000
VChrgSet : 0x28 , BatStat : 0x02
WD Disable stat : 0x0000
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
DA Stat : v3.2 on BBID : 0x84
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0015 , OEM : 0100
[eMMC] : FLASH_INF : M00U5
[eMMC] : FLASH_CID : 1501004E355530304D02BA994F4F301F
[eMMC] : FLASH_LEN : 0x00000000E9000000
INT RAM : 0x00020000
EXT RAM : 0x20000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Initial info read Ok!
Done!
Elapsed: 00:00:25
Reconnect Power/Cable!
Old 02-03-2015, 17:04   #2 (permalink)
Member: 1043909
Thanks Meter: 60,926
Hello,
Do you know what is required firmware version ?
Old 02-04-2015, 06:57   #3 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Wait for phone...
Phone found! [ 22 ]
Sync...
Boot Info :
BB_CPU_ID : 6575
BB_CPU_HW : CB00
BB_CPU_SW : 8A00
BB_CPU_SB : E201
i2c Init : 00000000
SpeedSet : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:00:25
Hello,
Does it stuck at logo after format with CM2MTK?
Format phone with FMT set to "0" in setting while format.
If still stck at logo after format with "0" setting do Fix DL Mode.
Br.
Page generated in 0.13198 seconds with 8 queries
