09-15-2016, 13:45 | #1 (permalink) |
No Life Poster Join Date: Sep 2004 Location: coast Age: 52
Member: 83397 Status: Offline Thanks Meter: 204 | I9082 hang on logo need flash file Operation : Check / Read Info [ v1.55 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 142 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8C00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : 00EC00BC00000055005400EC00BC0000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x008D , [SAMSUNG] KA100O015E_BJTT/KF94G16Q4V [NAND] : FLASH_DIE : 00EC 00BC 0000 0055 0054 00EC 00BC [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/01/NIM_Px-2 DEV RID : 0x7483792C79EFDCF6882B9A9A740D38B5 INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : alps ProdName : zr72_wet_lca ProdModel : zr72_wet_lca Device : zr72_wet_lca AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1.8 SECURITY : IMEI_SW [1] : 355236018806142 IMEI_SW [2] : 355236018806159 BTMAC Addr : 000046657201 WiFi MAC : 000000000000 Done! Elapsed: 00:00:16 Reconnect Power/Cable! Operation : Read Flash [ v1.55 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 142 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8C00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : 00EC00BC00000055005400EC00BC0000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x008D , [SAMSUNG] KA100O015E_BJTT/KF94G16Q4V [NAND] : FLASH_DIE : 00EC 00BC 0000 0055 0054 00EC 00BC [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/01/NIM_Px-2 DEV RID : 0x7483792C79EFDCF6882B9A9A740D38B5 INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... [Read Ok] : preloader_zr72_wet_lca.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : usrdata.img [ScatCFG] : MT6572 / V1.1.1 / zr72_wet_lca / NAND FW Size : 332 MiB Brand : alps ProdName : zr72_wet_lca ProdModel : zr72_wet_lca Device : zr72_wet_lca AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1.8 Android Info saved Scatter saved to : C:\Documents and Settings\jms\Desktop\I9082 bk\cm2\MT6572_NAND_alps__zr72_wet_lca__zr72_wet_lc a__4.2.2__ALPS.JB3.MP.V1.8 Done! Elapsed: 00:03:27 Reconnect Power/Cable! |
04-24-2017, 13:37 | #2 (permalink) |
Freak Poster Join Date: Feb 2008 Location: Faisalabad Pakistan
Member: 696491 Status: Offline Thanks Meter: 164 | Try this file Download Link Press Thanks if it helps you ! |
The Following User Says Thank You to netvision123 For This Useful Post: |
