Old 03-30-2016, 16:45   #1 (permalink)
MDK23's Avatar
Member: 467636
Sonork: Double Kanon
Thanks Meter: 2,620
i9190 nand format ok
1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : 002C00BC009000550056000000000000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0090 , [Micron] MT29C4G96MAZAPCJA_5IT [NAND] : FLASH_DIE : 002C 00BC 0090 0055 0056 0000 0000 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/01/NIM_Px-2 DEV RID : 96DD5583DDB91928C0B5E79E3FCE7B83 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : samsung ProdName : serrano3g ProdModel : GT-I9190 Device : serrano3g AndroidVer: 4.2.2 MTKxCPU : MT6571 MTKxPRJ : ALPS.JB7.MP.V1.14 Done! Elapsed: 00:00:15 Reconnect Power/Cable! Operation : Format FileSystem [ v1.44 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : 002C00BC009000550056000000000000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0090 , [Micron] MT29C4G96MAZAPCJA_5IT [NAND] : FLASH_DIE : 002C 00BC 0090 0055 0056 0000 0000 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/01/NIM_Px-2 DEV RID : 96DD5583DDB91928C0B5E79E3FCE7B83 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:13 Reconnect Power/Cable!
Old 03-30-2016, 16:48   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 14,670
You can change settings : Settings -> Other -> NAND init Mode
The Following User Says Thank You to JayDi For This Useful Post:
Old 03-30-2016, 18:54   #3 (permalink)
MDK23's Avatar
Member: 467636
Thanks Meter: 2,620
alive but still freez on logo
Operation : Check / Read Info [ v1.44 ]
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6571
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Brand     : samsung
Device    : serrano3g
AndroidVer: 4.2.2
MTKxCPU   : MT6571
SECURITY :
IMEI_SW [1] : 359883006313585
BTMAC Addr  : 000046657101
WiFi MAC    : 000000000000
Done!
Elapsed: 00:00:15
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6571
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:17
Operation : Repair Security [ v1.44 ]
Wait for phone...
Phone found! [ 4 ]
Sync...
Init Ok, waiting for phone ...
Reading initial info, wait...
Phone Info :
BB : MT6571, E00
HW : CENON71_ET_JB7_GPRS_HW
SW : MOLY.WR8.W1315.MD.WG.MP.V38
MM : 2000.00.00
VR : 1.0
SN : 0107E10303141103022801011405709331671361647020625_092830    10
Security Info :
IMEI [1] : 359883006313585
IMEI [2] : Damaged or not exists
Read Ok!
Update IMEI[1] to : 359883006313585 done!
Done!
Elapsed: 00:01:04
Old 03-30-2016, 19:10   #4 (permalink)
Member: 199814
Thanks Meter: 1,932
Team should improve nand format and read info i successfully used to read and write firmware. but same phone was unable to format. even selected all nand p1,p2 etc.
The Following User Says Thank You to asadnow2k For This Useful Post:
Old 03-30-2016, 19:16   #5 (permalink)
MDK23's Avatar
Member: 467636
Thanks Meter: 2,620
@asadnow2k
the same issue like u bro
Old 03-30-2016, 19:29   #6 (permalink)
JayDi's Avatar
Member: 462970
There is nothing improve. If format not helped - need seek FW. Nothing more will help.
The Following 3 Users Say Thank You to JayDi For This Useful Post:
Page generated in 0.25845 seconds with 7 queries
